Latch On Sliding Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 07:47 PM   #1
Latch on Sliding Door
Hi, I'm a real DIY newbie, so please be gentle.
We have a sliding wooden door (wooden door frame) between our house and our garage. The door currently has something fitted (I don't know what it's called) where if you push the top bit in, a bit on the bottom pops out so you can grab it and pull it to move the sliding door. I hope that description makes sense.
What we want is some sort of latch so that the sliding door, when closed, can't be opened unless you flick the latch. The problem is that we want the latch to be flickable (so that the door can be unlocked) equally easily from each side. The latch isn't for security, it's to keep the darn cat in the house, not the garage (he can actually open the sliding door. A latch will be enough to stop that).
I found some fittings that look like they'd do the job, but they had a latch only on one side - they were more for security. Or am I barking up the wrong tree? Is there an easier way to do this? The whole object is just to stop the cat being able to open it.
Thanks for any help/suggestions
Budfudder is offline   Reply With Quote
Old 09-10-2011, 07:53 PM   #2
Framing Contractor
Rewards Points: 126
We call that a pocket door. Don't usually see them between house and garage because it is not code compliant. Check to see if you can install a magnetic catch lock. Might be just enough to keep kitty cat from opening it.
sixeightten is offline   Reply With Quote
Old 09-11-2011, 03:01 AM   #3
Thanks for the suggestion - never heard of a magnetic catch lock, but having a look on the net they might be perfect. Just a question of how string the magnet is, I guess. I'll have a look and see if I can get one. Thanks a lot
Replacing a HUGE sliding glass door w/ a hinged patio door. ZeroTX General DIY Discussions 12 05-02-2013 10:39 AM
door latch and lock doesn't close properly grgryl Windows and Doors 7 07-25-2011 09:56 PM
installing door lock, door won't latch Sueflammer Windows and Doors 2 06-24-2011 06:31 AM
Replace sliding glass door weather seal imrook General DIY Discussions 1 10-16-2009 07:48 AM
Attic Door Latch tk3 Building & Construction 1 05-31-2007 04:50 PM
