Larson Storm Door Handle - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 07:29 PM   #1
Larson storm door handle
Guys that installed my storm door, installed the handle upside down. I have all screws out, but I cannot get the handles apart to turn handle around. How do the handles separate? It is a mortise door handle.
hvdavis is offline   Reply With Quote
Old 11-11-2012, 07:56 PM   #2
Rewards Points: 6,652
Need a picture on this one.
Old 11-11-2012, 08:20 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Generally speaking,the handle is held together with an Allen screw on the inside handle.
The outside handle will have the rod attached to it which gos through the door.
sublime2 is offline   Reply With Quote
Old 11-11-2012, 08:32 PM   #4
My door handle
My handle is opposite-you have to lift up to open!
Old 11-11-2012, 08:40 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
My door looks very similar to that but it's made by pella. The handle on mine will move up or down to open the door.
The Following User Says Thank You to sublime2 For This Useful Post:
Windows on Wash (11-11-2012)
Old 11-11-2012, 08:44 PM   #6
No, need a picture of your door that you are saying the handset is installed incorrectly, not some picture off of a websearch.
I have a Larson, and the handle moves up or down to open the door.
Old 11-11-2012, 08:47 PM   #7
door handle
So do I need a allen wrench to get the door handles off?
Old 11-11-2012, 08:49 PM   #8
Look at your door handle and you will find out. Again, a picture of how yours is installed, helps to tell you what to do. Mine is attached with two phillips screws. You remove the screws, the handle assembly comes apart.
http://www.larsondoors.com/storm_doors/troubleshooting/
You can also email Larson with the model# of the door, they will email you a copy of the Latch instructions if yours got tossed.
Old 11-11-2012, 08:57 PM   #9
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Did the installers leave the installation instructions?
There are instructions on how to install the hardware.
Old 11-12-2012, 07:09 AM   #10
Larson door handles
No, they did not leave the instructions.
Old 11-12-2012, 07:15 AM   #11
kwikfishron's Avatar
Rewards Points: 606
The installation instructions are here. http://www.larsondoors.com/storm_doo..._instructions/
kwikfishron is offline   Reply With Quote
Old 11-12-2012, 09:39 AM   #12
Those are only for the door, not the lockset. They have to email Larson Doors, and they will email a pdf of the door lockset instructions back to the OP.
Larson Storm Door timlynne General DIY Discussions 17 04-15-2012 11:16 PM
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 09:47 AM
Larson Storm Door won't close annoyed Building & Construction 8 03-23-2010 06:01 PM
Larson Storm Door Hinges af3683 General DIY Discussions 3 09-23-2009 11:42 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
