Larson Storm Door - Windows and Doors - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-16-2013, 07:49 PM   #31
Originally Posted by gregzoll View Post
Yes, due to if there is direct sun on that side of the house towards afternoon. My backdoor expands, but like I said, I fixed the hinge problem, by using a multi-tool to cut away a bit of wood, where the hinges were rubbing.
If the door has expanded, that it is catching the frame, you are going to have to undo the screws for the latch side of the frame and move it over a bit, if that is where it is catch. Same goes for the top, if it is catching there.
Like I said before, you can tell if it is catching, because there will be bare metal or rub marks, from it doing it over time.
I honestly can't tell where the pop is even coming from. I can feel it on my hand while the door closes.
valpd is offline   Reply With Quote
Old 07-16-2013, 08:16 PM   #32
Rewards Points: 6,652
You are going to have to listen for it, from the outside or inside, and then listen for it. If it is just you feeling it, you should be able to figure out where it is coming from then.
Old 07-16-2013, 08:31 PM   #33
kwikfishron's Avatar
Rewards Points: 82
It isn't Rocket Science.
The Baby is Screaming...Which way do I go?
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
gregzoll (07-16-2013)
Old 07-16-2013, 09:30 PM   #34
I know that , but it isn't easy in this case. Trust me.
Old 07-20-2013, 04:27 PM   #35
It looks like it's more apparent towards the right side where the handle is I just can't tell what make would such a loud popping sound there?
Old 07-20-2013, 04:43 PM   #36
My old storm door used to slam shut. I bought a new closer. 30 bucks..problem solved.
On my new Larson door, after about 6 months a loud pop began just as you describe.
The installation screws they provided were not long enough. I replaced them with 2.5 inch and problem solved
Try the longer screws first and then get a new closer. If it doesn't fix the problem you can take the closer back to the store.
creeper is offline   Reply With Quote
Old 07-20-2013, 04:47 PM   #37
Install screws all over?
Old 07-20-2013, 04:49 PM   #38
My door has two closers..I just replaced the screws in the bottom one
Storm Door Install pwgsx Windows and Doors 10 03-20-2013 02:53 AM
Can you mount a storm or screen door on this front door? daluu Windows and Doors 15 12-26-2012 04:55 PM
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 10:47 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
