Larson Storm Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-01-2013, 12:24 AM   #1
Larson storm door
I need help with 2 things. 1. We want to remove all of the gold trim around this screen door located around the glass of the door onside and out. Is that possible?
2. What door handle material is the next quality and rust resistant?
valpd is offline   Reply With Quote
Old 06-01-2013, 12:43 AM   #2
Rewards Points: 6,652
If you did, the top would cause the window to fall inwards, the bottom kick plate would allow critters and air to get through. As for the handle, it is just Pot metal. Your questions are really answered if you took the time to go to Larson's website and everything is available through their customer service link.
Now of course, you can paint the Brass parts, but then it would look cheap and shoddy.
Old 06-01-2013, 07:02 AM   #3
Rewards Points: 13,266
I think that color looks good with the white oak.
I sure hope that door way on the outside is not exposed to direct sun.
Those full view storms should come with a big warning sticker on them. They act like a solar panel and can distory a door.
Gymschu (07-16-2013)
Old 06-01-2013, 07:34 AM   #4
So your saying stay away from brass? What other type of handle material would you recommend?
Old 06-01-2013, 07:36 AM   #5
I also need to clarify. We want to substitute the gold trim for silver or brushed nickel.
Old 06-01-2013, 08:16 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
Call Larson. I am sure they will sell you the new pieces in a brushed nickel finish option.
Old 06-01-2013, 08:28 AM   #7
Otherwise stay with brass? We don't have brass currently. It sounds like the gold trim cannot be substituted which means I would have to get an entire new door.
Old 06-01-2013, 08:33 AM   #8
Also, I had to set the door to slam shut as its closing so it closes all the way. Otherwise it stays partially open instead of closing. What can I try?
Old 06-01-2013, 09:06 AM   #9
Who installed it? Is the alignment proper or is the closer not zeroing out.
Old 06-01-2013, 09:23 AM   #10
Its the closer.
Old 06-01-2013, 05:59 PM   #11
Never stated that. The parts you are talking about, are a "Brass" finish as described on Larson's website.
Old 06-01-2013, 06:07 PM   #12
I've yet to see one of those doors with that style latch close all the way on it's own.
I may if the inside door is still open but may not when the doors closed because of the pressure.
It's like trying to close a car door with the windows up, takes a little more ummp.
paul100 (06-06-2013)
Old 06-01-2013, 06:40 PM   #13
It it me a while to get my back door to close properly after putting in a new backdoor, and reinstalling the Larson Storm that we had. Still have a small gap at the top of mine, where I did not cut enough off the aluminum, but you can get them to close properly, by just taking your time, and doing the proper adjustments on the closer and latch.
Old 06-02-2013, 11:04 AM   #14
I got it to close at a much faster rate, but the latch will not automatically close. Instead it slams into the frame. What can I spray into the latch because it seems like its just jammed at times.
Old 06-02-2013, 12:17 PM   #15
If the latch is sticking, start with some graphite and see if it will loosen up.
If it doesn't, plan on pulling it apart and inspecting it.
Storm Door Install pwgsx Windows and Doors 10 03-20-2013 02:53 AM
Can you mount a storm or screen door on this front door? daluu Windows and Doors 15 12-26-2012 04:55 PM
Front Storm Door Won't Latch sciron General DIY Discussions 6 02-21-2011 10:47 AM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 08:22 AM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
