Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 03-31-2012, 07:09 PM   #1
MarginallyQualified
kwikset double key deadbolt removal
I got the two screws out but the bezel doesn't unscrew or pry off.
so, er, uhm... what's the trick?
thanks
Old 03-31-2012, 07:29 PM   #2
Ironlight's Avatar
thanks
The whole thing should just fall right out. The bezel is held in by the cylinder. At least that is how every two-key deadbolt I've ever seen is.
Are you sure it's not stuck to the paint on the door?
Ironlight is offline   Reply With Quote
Old 03-31-2012, 08:01 PM   #3
MarginallyQualified
Nope; no paint on the lock at all and the bezels do spin.
That's what I was expecting too.
When I was a younger man I'd have just jumped right in...
thought asking before getting out the hammer was wiser.
Old 04-01-2012, 07:46 AM   #4
MarginallyQualified
bump.
Anyone know what is going on with these (two) deadbolts?
How do I get them to come apart?
Old 04-01-2012, 07:55 AM   #5
the Musigician
DangerMouse's Avatar
How about photos?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 04-01-2012, 01:40 PM   #6
MarginallyQualified
For those who may come along in the future...
or if the search engine actually gets you to this thread:
After the two little screws next to the key slot are removed...
pry off the quarter sized trim plate those screws go through.
Beneath *that* plate are the screws that actually hold it all together.
Old 04-01-2012, 01:48 PM   #7
Ironlight's Avatar
Evil!
Old 04-01-2012, 03:23 PM   #8
Moderator
If you don't mind, TT, I'll throw this in for searchers landing here also.
If an egress (usually front entry) door, no key allowed per code in case of fire:
"R311.2 Egress door. At least one egress door shall be provided for each dwelling unit. The egress door shall be side-hinged, and shall provide a minimum clear width of 32 inches (813 mm) when measured between the face of the door and the stop, with the door open 90 degrees (1.57 rad). The minimum clear height of the door opening shall not be less than 78 inches (1981 mm) in height measured from the top of the threshold to the bottom of the stop. Other doors shall not be required to comply with these minimum dimensions. Egress doors shall be readily openable from inside the dwelling without the use of a key or special knowledge or effort." From: http://publicecodes.citation.com/ico...011_par001.htm
Thanks, Gary
Clothes taking longer to dry?
Double Keyed Deadbolt Lock stuck in locked position hubbard Building & Construction 17 07-23-2012 03:28 PM
Double switch wiring rockclimber Electrical 18 03-18-2012 11:13 PM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
