Keep My Old Wood Garage Doors Or Upgrade? (2 Year Live-in "flip" Home) - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 07:25 PM   #1
Rewards Points: 52
Keep my old wood garage doors or upgrade? (2 year live-in "flip" home)
Hello,
I'm trying to add value to my home and think that I need to upgrade my garage doors. This is something I know next to nothing about, but am learning.
The doors are wood and I've been told that makes them more valuable, but am not for certain on that.
Right now the doors are lifted by a single motor and are connected together by a wooden bracket (highlighted in red).
What should I do? Measure wheels, go buy new rails and a motor? (Then what about springs? Already had one blow up on me, very happy I wasn't standing next to it.) Hire someone? I'm pretty technically inclined and have remodeled 2 bedrooms and a bathroom so far in the house. In short, I'm cheap, and can learn.
white25rs is offline   Reply With Quote
Old 08-13-2013, 07:47 PM   #2
Rewards Points: 13,270
There's sure nothing special about those old doors.
And there for sure not increasing the value of the home. Just more mantaince with a wooden door.
If there not rotten or falling apart I'd leave them.
Someone Micky moused that door opener.
No way would I want both of my doors opening at the same time like that, each door should have it's own opener.
Old 08-13-2013, 07:50 PM   #3
Rewards Points: 52
I was wondering that too, but what are your reasons for that?
Old 08-13-2013, 08:00 PM   #4
Opener breaks and you loose both doors, if I was trying to heat or cool the garage I'd loose all the air.
A wooden door weighs a whole lot more then a steel or wooden door so you would have to have a bigger opener.
That has to be stressing the whole rail and roller system and the whole door frame by just lifting on one side like that
Old 08-14-2013, 11:23 AM   #5
Rewards Points: 52
Man I can't believe just how Mickey Mouse this is....
Old 08-16-2013, 12:11 AM   #6
Registered User
Rewards Points: 5,216
Those springs are rated for each side of ONE door (when getting a replacement- notice weight/size/material involved), call someone or research it more. That 1/2 hp motor is straining lifting both as it is designed to lift a single. Also add a horizontal 2x6 on top the bottom cord of the trusses supporting the door back-hang brackets, 1/2 the weight of both doors is on one/two trusses.... in the weakest middle-span area between webs.
Gary
Old 08-17-2013, 09:11 AM   #7
Rewards Points: 1,294
If the doors are balanced properly then the weight does not matter. The springs take the load. As for the broken spring, you need safety cables threaded thru them.
danpik is offline   Reply With Quote
Garage Door Framing help mystic_cobra Building & Construction 4 07-31-2013 10:14 AM
Wood vs Steel garage door sbkim Windows and Doors 8 07-06-2012 07:48 PM
Wood for a garage floor??!! CrossWorks Flooring 6 04-09-2010 09:28 PM
Garage doors and openers: repair or replace? walds11 General DIY Discussions 22 02-17-2010 05:04 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
