Just Picked Up A Use Patio Sliding Door What To Do Next? - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 09-19-2016, 06:14 PM   #1
Rewards Points: 241
Just picked up a use patio sliding door what to do next?
Got a heavy,older sliding door off craiglist for $50. Nothing came with the door. Im building a small room under a small patio what do i need to get from HD to install this? Thanks!
johnv713 is offline   Reply With Quote
Old 09-19-2016, 06:20 PM   #2
joed's Avatar
Rewards Points: 11,992
Re: Just picked up a use patio sliding door what to do next?
Did it come with the frame or did you just get a door?
Old 09-19-2016, 06:47 PM   #3
Rewards Points: 241
Just the door.
Old 09-19-2016, 07:09 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
You wasted $50. What you need to install it (even if you could find it) will cost more than a new door.
Coastal South Carolina
Old 09-19-2016, 07:09 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
Track rail, some carpentry skills, a lock/latch catch, router, etc.
Old 09-19-2016, 07:32 PM   #6
Rewards Points: 241
Hot dang it. So $50 down the drain?
Old 09-19-2016, 08:15 PM   #7
Property Mgt/Maint
Rewards Points: 718
Put it back on Craigs list!
joecaption likes this.
Yodaman is online now   Reply With Quote
Old 09-19-2016, 08:26 PM   #8
Rewards Points: 13,270
There's a reason it was a deal, no frame.
Old 09-19-2016, 10:26 PM   #9
Rewards Points: 241
This may sound like a dumb question but the wheels goes on the bottom or on top? My first time doing this.
Old 09-19-2016, 10:32 PM   #10
dd57chevy's Avatar
Rewards Points: 416
Got a heavy,older sliding door off craiglist for $50. [I][I][I]Nothing came with the door. Im building a small room under a small patio what do i need to get from HD to install this? Thanks!
OK , you say you bought a "door". Install it square & level ........
If you didn't buy a door , but bought a door slab , not sure what you should do .
PS: If this is the dumbest thing you have done this year , I gar-own-tee I could top it (in spades !!!)
dd57chevy is online now   Reply With Quote
Old 09-19-2016, 10:42 PM   #11
Rewards Points: 241
In retrospect it's probably the dumbest thing i did this year. But hey a newbie got to learn from his mistakes somehow
Old 09-19-2016, 10:44 PM   #12
Rewards Points: 220
lets see a pic of this door.
Fix'n it is offline   Reply With Quote
Old 09-19-2016, 11:17 PM   #13
Rewards Points: 241
Old 09-19-2016, 11:18 PM   #14
Rewards Points: 241
This one where you can see the wheel slot
Old 09-20-2016, 07:56 AM   #15
kwikfishron's Avatar
Rewards Points: 176
I pay $25 each for used tempered glass panels that I use for glass deck railings.
You have 4 of them so there is some value to what you have.
kwikfishron is online now   Reply With Quote
Sliding patio door in place of window ponch37300 Building & Construction 5 04-20-2016 08:26 AM
question about sliding folding patio doors Pawl Remodeling 1 11-07-2013 04:30 PM
question about installing sliding folding patio doors Pawl Remodeling 0 11-01-2013 06:01 PM
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 06:20 AM
Replacing windows with sliding patio door, should I match widths? TomServo Building & Construction 5 09-21-2009 08:22 AM
