Johnson Pocket Door Installation - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-01-2013, 01:49 PM   #1
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Johnson Pocket Door installation
Hey all,
Has anyone installed this pocket door? I already did the rough in and installed the kit hardware. Next, I will be installing the jambs for the pocket door. I'm trying to avoid buying the jamb kit since I can just buy jamb wood at the local Depot for a lot cheaper. But if you look at this image, you can see that the kit comes with a strike jamb that's 11/16" thick and split jambs that are 7/16" thick. Why the difference in thickness? Can I just use 11/16" for both the strike jamb and the split jambs since that's what I found at the store? I guess I could rip a 1/4" off the thickness of the board I have to make it 7/16", but was wondering if I really need to.
Thanks,
Jon
jonhayden is offline   Reply With Quote
Old 08-01-2013, 06:04 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
I just finished the rough-in on two of them. Like you, I'm not going to use their jamb kit.
I'm suspecting that the strike jamb is a thicker material so that it will hold it's shape better.
You and I are going to use straight lumber...but what about the guy who does not? That strike jamb is basically 3/4" thick...so it should stay pretty straight even if the studs behind it are not.
Old 08-01-2013, 06:07 PM   #3
Want to Learn
jonhayden's Avatar
Rewards Points: 135
So do you plan to use 3/4" for the split jambs too? Or are you going to rip a 1/4" off of it?
Old 08-01-2013, 07:02 PM   #4
JOATMON
ddawg16's Avatar
Depends on how much space I have for the opening......if I can use 3/4" stock and the washer and dryer will fit through the opening....I'll do what ever is easiest.
At this point, I'm inclined to use some corner molding....but that actual part of the project is about 4 months away....right now I need to finish my 2-story addition....
Click on the link in my signature and you will see what I'm talking about.
Old 08-01-2013, 10:14 PM   #5
Want to Learn
jonhayden's Avatar
Rewards Points: 135
Wow! That's quite a project! Pretty awesome.
Looking at pocket doors... HT4Me Building & Construction 19 05-06-2013 10:56 PM
Shower next to pocket door? CMB00 Kitchen & Bath Remodeling 12 01-08-2013 06:58 PM
Pocket Door Wheel AZSun Carpentry 2 10-09-2012 09:01 PM
pocket door between kitchen and laundry jarleifvaagen Building & Construction 7 02-13-2011 07:55 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 05:26 PM
