Jeld-Wen Premium - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 11:26 AM   #1
Rewards Points: 768
Jeld-Wen Premium
I know most say to stay away from Menards, etc. Big box stores for windows, but Menards sells Jeld-Wen and you can special order Jeld-Wen Premium windows (not the builder grade they assume you want). The base of these premium windows have a U-value of .29 and pressure tested of DP-20 (you can upgrade to DP 50 with adding features like Low E3, triple glazing, etc. These windows would then have a u-value of .23.
Any feedback on Jeld-Wen premium. The specs are better than other windows specialsists offer at a very similar or cheaper price tag.
cibula11 is offline   Reply With Quote
Old 09-18-2013, 11:44 AM   #2
Rewards Points: 156
How much?
Those are good numbers
strategery is offline   Reply With Quote
Old 09-18-2013, 12:25 PM   #3
Rewards Points: 768
Originally Posted by strategery View Post
How much?
I was quoted $255 for a 28x56 double hung Jeld-Wen...this one had a u-value of .29 and DP of 20. I would guess that for another 20-30 I'd could improve both numbers. Menards is also running an 18% off sale right now which could save me 50+ on each window. (I need 6).
The other product, Vector, is running me $280 for the same white double hung and gives a U-value of .29, but a pressure rating of DP 40.
If there's a compelling reason to go with one or the other, I would, but I can't seem to find one myself.
Old 09-18-2013, 07:22 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Both are mediocre at best IMO. Quality vinyl windows are getting u-values as low as .25-.26 in double pane, DP 50 WITHOUT reinforcement (60+ with it), and air infiltration rates as low as .01 cfm (in double hung). I don't know the exact AI rates of either of those products, but I would guess that both are between .15-.20 at best.
Okna/Himark, Softlite, Sunrise, Polaris, and Vytex all have excellent choices in that range.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 09-18-2013, 08:24 PM   #5
Rewards Points: 768
Thanks for the help. I had another question...
When ordering the double hung, I have the option of a sloped sill or pocket sill. Is there a preference or advantage of one over the other. It seems as though all of the other double hung windows I have ordered in the past look like a pocket sill. Just curious as to the differences and if one is preferred over the other.
Old 09-18-2013, 10:17 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Absolutely! A welded sloped sill is always preferred. A pocket sill will channel water through the frame, and over the years it can block up causing issues from minor to catostrophic. It is an obsolete design IMO, and all of the top performing products today utilize a welded sloped sill design.
www.HomeSealed.com
Old 09-18-2013, 10:28 PM   #7
Rewards Points: 768
How would I know if it were welded? Or is this implied bc it's sloped?
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 11:46 PM
Windows? Erickp40 Windows and Doors 5 11-17-2011 11:53 AM
Behr Premium Plus Ultra beachnik Painting 2 06-15-2009 05:36 AM
tiling with PL premium tonia Tiling, ceramics, marble 5 05-14-2009 09:23 AM
Storing PL Premium construction adhesive Nestor_Kelebay General DIY Discussions 14 12-19-2008 08:03 AM
