-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Jeld-Wen Premium (http://www.diychatroom.com/f104/jeld-wen-premium-187185/)
cibula11 09-18-2013 10:26 AM
Jeld-Wen Premium
I know most say to stay away from Menards, etc. Big box stores for windows, but Menards sells Jeld-Wen and you can special order Jeld-Wen Premium windows (not the builder grade they assume you want). The base of these premium windows have a U-value of .29 and pressure tested of DP-20 (you can upgrade to DP 50 with adding features like Low E3, triple glazing, etc. These windows would then have a u-value of .23.
Any feedback on Jeld-Wen premium. The specs are better than other windows specialsists offer at a very similar or cheaper price tag.
strategery 09-18-2013 10:44 AM
How much?
Those are good numbers
cibula11 09-18-2013 11:25 AM
Originally Posted by strategery (Post 1243247)
How much?
I was quoted $255 for a 28x56 double hung Jeld-Wen...this one had a u-value of .29 and DP of 20. I would guess that for another 20-30 I'd could improve both numbers. Menards is also running an 18% off sale right now which could save me 50+ on each window. (I need 6).
The other product, Vector, is running me $280 for the same white double hung and gives a U-value of .29, but a pressure rating of DP 40.
If there's a compelling reason to go with one or the other, I would, but I can't seem to find one myself.
HomeSealed 09-18-2013 06:22 PM
Both are mediocre at best IMO. Quality vinyl windows are getting u-values as low as .25-.26 in double pane, DP 50 WITHOUT reinforcement (60+ with it), and air infiltration rates as low as .01 cfm (in double hung). I don't know the exact AI rates of either of those products, but I would guess that both are between .15-.20 at best.
Okna/Himark, Softlite, Sunrise, Polaris, and Vytex all have excellent choices in that range.
cibula11 09-18-2013 07:24 PM
Thanks for the help. I had another question...
When ordering the double hung, I have the option of a sloped sill or pocket sill. Is there a preference or advantage of one over the other. It seems as though all of the other double hung windows I have ordered in the past look like a pocket sill. Just curious as to the differences and if one is preferred over the other.
HomeSealed 09-18-2013 09:17 PM
Absolutely! A welded sloped sill is always preferred. A pocket sill will channel water through the frame, and over the years it can block up causing issues from minor to catostrophic. It is an obsolete design IMO, and all of the top performing products today utilize a welded sloped sill design.
cibula11 09-18-2013 09:28 PM
How would I know if it were welded? Or is this implied bc it's sloped?
