-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Jamb extensions on a door? (http://www.diychatroom.com/f104/jamb-extensions-door-158836/)
freeclimbmtb 10-03-2012 11:19 AM
I installed a slider a few months back and finally have some time to finish trimming it in. The door has about a 6-8 inch recess from the interior wall, the old door had the returns finished with drywall with a victorian style casement around the outside edge. Instead of messing around with cornerbead, I want to simply use 1" pine boards as "jam extensions" like on a window, and then just have the actual trim overlap the pine for a finished corner. (mitred corners, that victorian look just bad in the room)
Anyreason NOT to do this? Ill take tricky cuts and priming over messing with cornerbead any time I can get away with it.
DannyT 10-03-2012 02:52 PM
all of my windows had the same treatment so when i redid each room i tore off the drywall, installed jambs and trimmed them out. many builders will use drywall instead of jambs because it saves money but looks pretty plain to me. your plan sounds great and will look much better.
freeclimbmtb 10-03-2012 03:04 PM
So no issue using this technique on a door frame? Perfect.
sixeightten 10-03-2012 04:31 PM
Could be an issued. Depends on which way the door swings. I have seen some where the strike would hit the jamb when they are that wide.
mae-ling 10-03-2012 04:51 PM
It is a slider, so no swing problems. I usually keep my extensions back 1/8" from the existing jamb edge. really hard to get it perectly flush in the field.
HomeSealed 10-03-2012 07:45 PM
No problems. Good plan :)
freeclimbmtb 10-04-2012 07:13 AM
As mae-ling said, its a slider so theres no issue with swing. I am going to shoot for enough overlap to cover the sealing groove (see below)
http://image.made-in-china.com/2f0j0...le-DMA117-.jpg
This isnt exactly what ive got, but it shows the basic profile..ish. Bottom right cutaway, top and bottom right corners there is a square pocket (im assuming for calking) So Im going to plan on my jams covering that, I dont mind a step, so as long as that groove is covered, I think I'll be happy with it.
While Im on the subject, should I use any sealant on the interior between the Jam and the vinyl frame? I was thinking just to keep the jam from having any sort of gap agains that edge i might use some white silicone or something...its tight on the exterior so im not worried about weather/infiltration...just aesthetics..
