Jamb Extensions - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 09:32 AM   #1
CrashBob's Avatar
Jamb extensions
Howdy,
I need to install jamb extensions around a vinyl cased patio door. Any good suggestions on how to attach oak extensions to the vinyl?
CrashBob
CrashBob is offline   Reply With Quote
Old 04-26-2011, 12:03 PM   #2
Residential Remodeler
Don't worry about attaching it to the vinyl.
Attached it to the framing with finish nails and caulk between the oak jamb extension and vinyl door (if desired).
CookeCarpentry is offline   Reply With Quote
Old 04-26-2011, 10:54 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Cooke is right, I'd only add that you'll likely need to add shims behind the extensions to "build them in" to sit where you need them to. You can nail into the vinyl if absolutely necessary, but prepare for the warranty to be void if you do so.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
NEWBIE QUESTION ALERT!! Jamb Extensions Evil Scotsman General DIY Discussions 24 04-12-2011 06:30 PM
Sizing Jamb Extensions smacman Building & Construction 3 06-29-2010 01:06 PM
Window jamb extensions wmjdr Remodeling 7 06-07-2010 08:50 PM
Reducer scribed to fit door jamb? Please Help!! joemontana16 Flooring 1 03-14-2010 11:47 AM
Window Jamb Extensions Tom5151 Carpentry 27 09-25-2009 10:40 AM
