Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-12-2012, 03:42 PM   #1
Interior Side of a Window
Hello everyone,
I need some help with a window. I installed a new interior window. The depth of the window is less than the 3x4s thus on the interior side of the window I have about a 2" that is not covered by the window. I am talking about the inside of the frame where the flashing goes. However, since it is an interior window I did not put any flashing on it so I have the bare 3x4s now. What can I do with that? Should I just cover it with thin and long strips of drywall and paint it or are there other options? Could I put a couple layers of joint tape directly on the wood, joint compound and paint over it? Or maybe some wodden strips? I hope I explained this well enough.
Thanks for your help
DIYLoverKS is offline   Reply With Quote
Old 10-12-2012, 05:52 PM   #2
Windows & Remodeling
HomeSealed's Avatar
I'm having a hard time deciphering exactly what you are talking about... A pic would be a tremendous help.
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
mae-ling (10-12-2012)
Old 10-12-2012, 05:57 PM   #3
Inside window?
3 X 4's
I second the vote for some pictures, none of that make since to me.
gregzoll (10-13-2012)
Old 10-13-2012, 04:38 PM   #4
AHH, SPANS!!!
the interior trim profile design already in your home will match and attach to the window. Do you have drywall on the wall around the window or waas it not needed?
hand drive is offline   Reply With Quote
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Defog window recap greenmax General Discussion 4 05-07-2010 06:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
