Interior Door Quality: Masonite Vs IMP - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-26-2012, 04:29 PM   #1
Send a message via Skype™ to kutsyy
interior door quality: Masonite vs IMP
I am installing dual 10-lite Finger Jointed Pine Primed pocket door and I am trying to decided on the brand. Currently I am choosing between IMP and Masonite. I know that Tru-Stile is better, but they are 5x more (I need each slab to be standard 32"x80"x1 3/8").
Any recommendations?
Thanks,
Vadim
kutsyy is offline   Reply With Quote
Old 03-26-2012, 07:24 PM   #2
Rewards Points: 512
im not a fan of the masonite doors, well the jamb actually. the stop is moulded into the jamb and cant be moved or adjusted. also i dont like whatever coating they put on them. you accidently get a bad shot with the brad nailer and you get a blow out and it all blows apart and is a pain to repair. i dont believe that we have the other brand in my area so i cant comment on it
princelake is offline   Reply With Quote
Old 03-26-2012, 09:45 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
well. there is a reason behind the saying, you get what you pay for. ive hung countless masonite doors and i find them to be a lower quality product. if im using a lower cost door i prefer jeldwens but for solid doors i prefer milan' from quebec.. at least thats what i think their called, they generally run about $150 each and are made of solid pine as oposed to masonite solid doors which are simply a veneer over mdf
woodworkbykirk is offline   Reply With Quote
Old 03-27-2012, 06:33 AM   #4
You said "pocket doors", 1 3/8 thick??? So I assume these are on the interior??? As suggested above, there are good and not so good doors, but interior doors don't require weather resistance. I would say, use whatever fits your decorating needs.
A 9 lite door for the interior is not a common thing, how about french style doors??
Beware Masonite doors Jeremy Hillary Boob, PhD Building & Construction 14 03-14-2013 10:01 PM
Masonite patio door DERVID_W Building & Construction 2 04-07-2011 06:41 AM
Will drywall mud, mud&tape stick to masonite? Hossenfeffer Building & Construction 4 08-25-2010 06:15 AM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 08:57 AM
Can I tape joints on old masonite walls? ETD66SS Building & Construction 9 11-13-2009 05:09 AM
