Integrated J Channel Option - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 11:34 PM   #1
integrated J channel option
Is having a new construction window with integrated J channel a good thing if you are using hardy plank or cedar shake siding? Also I am using a geometric window (circle top). Aesthetically would a window without the J channel and having the siding butt up to a casing be better.
Does the J channel help out if the window is properlty installed?
jack09 is offline   Reply With Quote
Old 02-29-2012, 08:05 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
http://www.jameshardie.com/pdf/USTB_...-J-Channel.pdf
you can use integrated j but you need to follow these details with hardie
wood shakes? hmmm... maybe i wouldn't,what do you say Ron?
the other concern would be the width of the pocket and the thickness of the installed siding
the other thing you may want to consider is future window replacement,independent window trim will make replacement much easier
Tom Struble is offline   Reply With Quote
Old 02-29-2012, 10:07 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
As Tom's link shows, it can be done, but it would not be my choice. They still call for additional flashing on the top and bottom so it would seem like a waste to me... and probably look kinda weird. I prefer the look and functionality of separate trim around the window.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Tom Struble (02-29-2012)
Air infiltration in vinyl windows with integrated J Channel tom34 Carpentry 2 12-15-2010 06:58 AM
Air infiltration in vinyl windows with integrated J Channel tom34 Building & Construction 5 12-14-2010 07:54 AM
Help! Casings around window with integrated J channel? Learn2Build Remodeling 8 06-01-2010 06:10 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 03:29 PM
Window casings around window with integrated J channel? sandyman720 Building & Construction 11 10-02-2007 02:15 AM
