Insulation Under The Bow Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 08:04 PM   #1
Insulation under the bow window
our entire bow window was taken out, frame and all. I noticed there was very little insulation underneath from the original installation. Shouldn't the window installers put insulation underneath as well as the foan on the sides and inbetween the windows? Like regular insulation? Isn't this code?
pwhite is offline   Reply With Quote
Old 06-19-2011, 09:08 PM   #2
DIY staff
Rewards Points: 7,174
Code? You need to put your location in for that answer---codes vary.
You may need to have some box work built to accommodate more insulation--1 1/2" or 2" foam usually is enough--unless you live far north.---Mike----
Old 06-25-2011, 08:48 AM   #3
Custom Home Builder
Always a good idea to install insulation at the bottom side.
I install a 1x4 around the bottom of all of the bows and bays I install and then fill the cavity with insulation.
Finish it off as desired.
thomasjmarino is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 04:09 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Shrink film window insulation, no kit EscarHolmez General DIY Discussions 3 12-28-2008 12:05 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
