Insulating A Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 01:27 PM   #1
Rewards Points: 154
Insulating a window
I'm installing a vinyl picture window that has a nailing flange. I'm using spray foam to insulate the gaps. I have a sill pan installed which is designed to collect and throw out any errant moisture. Is filling the gap on the lower edge going to interfere with this function? How would you prevent air leaks from the lower edge of the window otherwise? The window only insets into the framing about 2 inches so the foam would be hard to control.
ovahimba is offline   Reply With Quote
insulating metal window frames hawkk Windows and Doors 2 05-04-2011 01:08 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 09:52 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
