Insulating/Retrofit Old Wood Sash - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-17-2011, 04:09 PM   #1
We just bought a home built in 1931 and has the original windows with the charming wavy glass, solid wood of course. Nearly every window has at least one counterweight cord missing and during our home inspection the inspector said they make a product that is essentially a vinyl liner that you install on the sides of the sash allowing you to insulate the cavity where the counterweight would go and obviously remove them. He didn't know what to call it and after some googling I've yet to find what he is looking for.
Any ideas on what he was talking about?
corey07850 is offline   Reply With Quote
Old 09-17-2011, 11:46 PM   #2
Are you planning on just taking the remaining weights out to insulate it? If you are you could just use foam boards cut to size.
edit: Sorry I haven't heard of the liner before though
banjo is offline   Reply With Quote
Old 09-18-2011, 10:40 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,172
You are referring to a compression jamb liner and the weight boxes should be insulated with foam or another medium.
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 07:46 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
Problems with Pella ProLine double-hung breaking when clenaning jpsmith Remodeling 5 04-15-2009 12:09 PM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
