Insulated Glass In Storm Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-21-2013, 04:49 PM   #1
Insulated glass in storm door?
I am considering installing a new storm door and am trying to evaluate the pros and cons of the 3 glass types offered by the Andersen 4000 series , tempered single pane glass, low e glass or insulated glass.
We may leave the entry door open on sunny fall winter and spring days
for the added light.
ehand is offline   Reply With Quote
Old 05-21-2013, 05:23 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
Insulated glass in a storm door is a waste of money. Even the best insulated glass does little for the R-value and the doors are rarely weatherstripped and fit properly. Normally, the door itself does not have ant better insulation value. You never get the savings compared to the additional cost and weight.
The best thing storm doors do is divert the wind and rain (when the glass is in place.
Dick
concretemasonry is offline   Reply With Quote
Old 05-27-2013, 08:23 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
+1 to CM's assessment.
Not sure you would even want an insulated door either.
Most folks don't pull the glass in the summer either and the insulated glass would probably trap way to much heat against the door.
**Note to people using storm doors - you need to remove the glass when the weather gets warm**
Old 05-27-2013, 09:01 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
+2 on cm's comments as well.
Side note on gas...you will frequently see Argon as the insulating gas. The R value of Argon is only fractionally better than air. For a storm door, It's not worth the additional cost. If they toss it in for free...sure....
Just make sure they use tempered glass.
When we were getting new windows for our addition....I was surprised at little extra cost tempered was....I think it maybe added $50 on average to the windows. We ended up making the windows next to the driveway tempered......boys....basketballs....yep...tempere d.
Old 05-27-2013, 10:02 PM   #5
Insulated glass is way too heavy for a storm door. It will sag in no time flat.
mknasa dad is offline   Reply With Quote
Patio Glass & Door Question LittleHey Windows and Doors 4 03-28-2013 07:33 PM
Brick molding too shallow for storm door axenol Windows and Doors 7 03-06-2013 09:33 AM
Pella Sliding Glass Door Repair/Replace exocet Windows and Doors 5 03-19-2012 06:28 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Storm Door Selection/Brand Advice Wanted kc27 General DIY Discussions 3 10-25-2009 08:17 AM
