Insulated Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-14-2012, 04:03 PM   #1
Insulated doors
Two single insulated Thermatrue doors facing windward. Both leak under wind-driven rain. Known? Fix?
arc001 is offline   Reply With Quote
Old 03-14-2012, 06:34 PM   #2
Rewards Points: 1,578
What area of the door is leaking, top, side(s), bottom...?
Are these two separate doorways or do these butt?
bob22 is offline   Reply With Quote
Old 03-14-2012, 06:50 PM   #3
Rewards Points: 13,446
Missing or damaged door threshold seal. Anyones guess with that little bit of info.
Old 03-15-2012, 06:28 AM   #4
Threshold seal not adjusted tightly.
Latch plate does not hold door tight against weatherstrip.
Poor installation.
That is one of the best doors systems you can buy, properly installed and adjusted, there should be no problem. You might consider a storm door.
The Following 2 Users Say Thank You to Just Bill For This Useful Post:
HomeSealed (03-15-2012), Windows on Wash (03-15-2012)
Old 03-15-2012, 10:57 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Can't add anything to Bill's post.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Made My Own Inexpensive Wood Garage Carriage Doors iffy Project Showcase 4 03-31-2012 02:07 PM
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 06:42 AM
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
