Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-17-2012, 11:11 AM   #1
Installing Simonton Brickmould 600 vinyl windows in new construction opening
I am having my sunroom remodeled. They have removed the existing walls and have build new stud walls. The framed opening for the windows is 4" wide. The problem is that the part of the window that sits inside the framing is only 3" wide.
Does anyone know if there is an additional frame piece for the Simonton window that I don't have?
Any information would be greatly appreciated. Thanks.
Projectsgalore is offline   Reply With Quote
Old 01-17-2012, 11:17 AM   #2
There going to add jamb extentions. Yes they could have ordered widows with wider jambs, but it's cheaper in most cases to just make them. Just simple pieces of 1 X pine in most cases.
Old 01-17-2012, 11:31 AM   #3
Thanks so much for your quick reply!
So the jamb extensions will extend from the end of the window frame to beyond the frame opening?
Does that mean that the sheetrock will sit up again the extended piece of the jamb extension?
Will I have to worry about the installation somehow voiding my warranty?
Old 01-17-2012, 11:50 AM   #4
The jambs touch the window frame and sit flush with the sheetrock, then the casing goes on.
Not sure why you would think this would have any effect on the warrenty, nothing gets attached to the window it's self. Almost every new constrution window ever installed is done this way.
Why are you not asking the guys working on this these questions?
Tom Struble (01-17-2012)
Old 01-17-2012, 12:25 PM   #5
Windows & Remodeling
HomeSealed's Avatar
I agree with joe on all points.
HomeSealed is online now   Reply With Quote
Old 01-17-2012, 12:26 PM   #6
Thanks again. I wanted to have some information before I spoke with my contractor (I really am a newbie!)
Vinyl replacement windows. joefromcal Building & Construction 8 02-20-2011 10:54 PM
Replacing Vinyl Windows w/o Nailing Fin irish Building & Construction 1 06-03-2010 11:37 AM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 01:48 PM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 08:36 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
