Installing New Sliding Patio Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-13-2013, 12:59 PM   #1
I'm replacing an old set of french doors leading out to the patio with a new sliding door. Any suggestions on what I should look for, or look out for, when purchasing the new door. Some folks tell me to use a sill pan, others tell me not to worry about it. Just looking for your advice on these 2 things.
zippster75 is offline   Reply With Quote
Old 05-13-2013, 03:22 PM   #2
Rewards Points: 13,446
A sill pan is by far the best way to go, it can also be done with window tape and flashing.
Main reason most sliders leak and rot out is because of poor or no flashing, and there installed to close to any solid surface. A porch, stoop, deck within
6" of the threshold can cause all types of issues.
There also needs to be a something installed along the whole underside of the threshold to support it.
I like to use 3/4" vinyl lumber tight up againt it held in place with SS trim head screws.
DO NOT use a 2X, it sticks out to far and will funnel the water under it.
Old 11-20-2013, 10:02 AM   #3
Dave88LX's Avatar
Rewards Points: 564
Joe,
Do you have a diagram of what you are talking about? I'm trying to visualize this...
Thanks.
Dave88LX is offline   Reply With Quote
Old 11-20-2013, 05:45 PM   #4
http://www.jamsill.com/
Door thresholds stick out past the side of the house about 1".
Unless there's something up under it it's going to flex and crack the side seals.
Old 11-20-2013, 07:34 PM   #5
Dave88LX's Avatar
Rewards Points: 564
I wish anyone local carried something like that.
Old 11-20-2013, 11:52 PM   #6
Dave88LX's Avatar
Rewards Points: 564
I can order Jamsill on Amazon and get it Friday.
http://www.amazon.com/Jamsill-Door-W...ywords=jamsill
That is the right one, yes?
I noticed the old slider's threshold where it overhung was all spongy bent down. Probably partially due to it being a terrible subfloor to begin with, but, did not have any under support either.
I saw another post of yours where you talked about using some sort of vinyl board. If I go this route, it will just have to sit on the top of my deck. Is this OK? Would the Jamsill go OVER the extra piece of vinyl board, or is it something that is attached afterwards? I can't see how the Jamsill would go over it, as it wouldn't fit correctly in the corner.
Adhesive, screws, or both?
Old 11-21-2013, 12:16 AM   #7
Dave88LX's Avatar
Rewards Points: 564
OK found it:
vinyl siding below door
I use 1 X 6 or 4" Vinyl lumber attached with stainless steel trim head screws pushed up tight under the threshold.
Than J mould around it.
Run it all the way out to the outside edges of the vinly brick moulding so the J will cover up the ends of the vinyl lumber.
You also need to flash that door opening before the door goes in.
http://www.bing.com/images/search?q=...electedIndex=4
And add a strip of Z moulding over the top of the door before the J goes on.
Nope, just 3/4 vinyl lumber will work.
Main thing is it has to sit under the threshold not ever stick out past it.
I've made a ton of money when some builder cheaps out and uses a pressure treated 2 X 4.
It ends up acting like a funnel and rots out the subfloor and rim joist.
Ching ching, show me the money.
Old 04-15-2014, 09:54 AM   #8
Vinyl lumber for the support goes in first, then the jamb sill so the outside lip on the jamb sill will hang over it.
The Jamb sill is just nailed with roofing nails where it runs up the R/O on the two outside edges, never in the bottom of it.
Old 04-16-2014, 01:52 AM   #9
dwaynesmithz's Avatar
Rewards Points: 12
I would agree to Steven James. Patio door glass is more attractive that wooden.
dwaynesmithz is offline   Reply With Quote
Patio sliding glass door doubleJ Windows and Doors 2 02-19-2012 12:51 AM
Framing and installing new patio door in older home MurphyMan Building & Construction 0 12-28-2011 06:56 PM
6" Sliding Patio Door in a 4" Wall mharrima101 Windows and Doors 13 11-12-2011 01:11 PM
sliding patio door header... sharp Remodeling 2 11-03-2009 03:50 PM
Replacing sliding patio door problems marlinpuppy Building & Construction 2 02-22-2009 08:11 PM
