Installing A New Front Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 09:33 AM   #1
Ute
Installing a New Front Door
Trying to install my door I noticed that it is sticking and seems not square. Do I lift up on one of the sides and shim under it? Or do I just shim the sides?
Thanks for your advice
Ute is offline   Reply With Quote
Old 10-19-2011, 11:21 AM   #2
First you level it side to side by shimming under one side as necessary.
Then you shim the sides to plumb/square and nail it.
Usually, you can just pull the shims out from the bottom once it's nailed.
GottaFixIt is offline   Reply With Quote
Old 10-19-2011, 08:58 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The hinge side is key.... plumb the hinge side, level the sill (with shims if necessary), then shim the top and latch side for an even reveal. That's it.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-20-2011, 07:42 AM   #4
A door a day is all I ask
TheDoorGuy's Avatar
I would add is that you should caulk under the sill with
polyurethane caulking, more so if you have to shim to level it.
Don't use silicone...It doesn't bond as well.
Fill around outside of frame with window and door spray foam
for a good seal and to hold everything together.
RC/DG
Richard The Door Guy
www.thedoorguy.com
TheDoorGuy is offline   Reply With Quote
Old 10-24-2011, 12:15 AM   #5
This is what I do:
level first by placing plastic shims every 4'' under the door. Run a thick bead of caulk as well, then put door in opening
once door is in opening and is centered and checked for level, shim the hinge side plum, and fasten.
Use the door to ensure nice reveal for latch side, shim and fasten. I usually like to hide the screws beneath the weather stripping.
chrisBC is offline   Reply With Quote
Fullview storm door with stained wood front door matjam68 Remodeling 1 05-06-2010 07:18 AM
Paint not covering my exterior front door rlbrown4253 Painting 5 03-15-2010 05:11 PM
New prehung front door not right lofar Carpentry 10 06-18-2009 03:00 PM
Rehanging an exterior basement door tputkey Building & Construction 9 05-21-2009 04:19 PM
