Installing A New Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 11:42 PM   #1
Rewards Points: 258
Okay I have a door opening that I want to install a door in. It looks like it once had a bi fold door and has dry wall texture around the inside face. So I just need a check on making sure I have the process down for how to install a new pre-hung door. The opening is 33 7/8 wide to the finished edges and 81 inches tall from finished floor to finished inside. So I know I need to take it down to the stud on the inside what is the best way to do this? Then I will need to shim the new door looking at 30 inch door. Then trim and paint I the door needs it. What did I miss?
redman88 is offline   Reply With Quote
Old 07-09-2013, 08:11 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 710
You are on the right track, except I suspect that you will need a 32" door based on the measurements. Definitely cutback the interior finish in those jambs though to get to the RO.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 07-09-2013, 10:17 AM   #3
Rewards Points: 258
Thanks that's what I was thinking in the back of my head but wasn't to sure
Old 07-09-2013, 12:46 PM   #4
funfool's Avatar
Rewards Points: 534
You might want to rethink this a little.
You want ro to be 3" wider then the door typically. 33 7/8 you could install a 30" door in the opening as is.
I would rather it be to studs and not drywall over the studs.
What I see is wallpaper, and the drywall is going to have corner bead. Will be a little tricky cutting back the paper to remove the corner bead without damaging the wallpaper. You can do it. You only have 2 1/4" trim plus the amount you shim.
You just do not have a lot of wiggle room. Of course, you can have trim as wide as you want.
Could be a lot of extra work to get a 32" door, if you are happy with a 30" door.
funfool is offline   Reply With Quote
Old 07-09-2013, 02:52 PM   #5
kwikfishron's Avatar
Rewards Points: 92
I've never seen a need for a RO to be 3” wider than the slab assuming 3/4” jamb stock, 2” wider is the norm, 2 1/2" for 5/4 jambs. There should be no problem with a 32” door going into a 33 7/8” opening as long as the opening is relatively plumb.
The 81” height may be an issue though since most interior doors are 81 1/2” tall.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
HomeSealed (07-09-2013)
Old 08-19-2013, 05:50 PM   #6
Rewards Points: 258
What's the best way to remove the dry wall from the opening? Or should I just sand the dry wall smooth and install the new door over the dry wall
Old 08-20-2013, 12:50 AM   #7
Rewards Points: 258
No tips?
Old 08-21-2013, 11:16 AM   #8
Rewards Points: 87
Just take a hammer and cutting tool (chisel, prybar) to the drywall in the opening. Take care not to bash the corners too much. If I was hanging a slab door (not pre-hung) I'd probably go with a 32" door. I'd also replace the interior around the top and right, because I'd put casing around the opening on both sides, and I don't think your existing interior bits will work with casing due to their shape.
Re: the door height, a slab door you should be able to trim 1/2" no problem.
huesmann is offline   Reply With Quote
Old 08-21-2013, 12:24 PM   #9
Rewards Points: 258
Got to love it when people take the time to do things right. If you can't tell they tiled around the the base board
Old 08-21-2013, 02:08 PM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Flooring is not my forte, but I don't believe that is entirely wrong to do so. Generally you'll have a base shoe then added. They probably tiled sometime long after the base moulding had been in place.
www.HomeSealed.com
need help installing door sweep! screws won't go in doitmyself89 Windows and Doors 6 09-24-2012 09:46 PM
installing a new door in an existing wall wengang1 Remodeling 2 05-06-2012 01:20 PM
Installing a cat flap/pet access door on a standard interior panel door? GordCooper Remodeling 7 03-08-2012 10:02 PM
Installing exterior door 99miles Carpentry 11 03-30-2011 07:01 AM
