Installing Interior Door Over Drywall? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-30-2014, 03:31 AM   #1
Rewards Points: 83
Installing interior door over drywall?
So I have a living room with an approximate 5 ft opening. I will be converting the room to a bedroom and installing a double interior door. Can I just install the door jambs directly to the existing drywall over the studs or do I need to remove it to expose the wall studs?
I know typically you attach the jambs directly to the studs but if I could just keep the drywall there it would make it a lot easier in a few years when I go 2 sell and convert it back to a living room.
AllGoNoShow is offline   Reply With Quote
Old 01-30-2014, 04:46 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,624
Installing inside the drywall opening will damage the drywall to the extent that it will require repair regardless if you return it to its pre-door state.
I would rely moreso on what you need the size to be (understand that a custom size door will be more expensive than a standard size opening) and use that as the determinant of what you need the RO to be.
Drywall is cheap at the end of the day and the repairs won't be that bad up or down.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (01-30-2014)
Old 01-30-2014, 04:55 AM   #3
DIY staff
Rewards Points: 7,174
One draw back to leaving the drywall---the opening is to wide for standard 4 5/8" jambs--the corner bead adds to the width----thus making the installation and trim really time consuming.
Drywall Damage After Wallpaper Removal katega Painting 10 01-26-2012 10:21 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Installing wood casing around door, issue with drywall titan7 Carpentry 9 09-15-2011 05:08 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 01:08 PM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 06:07 AM
