Installing A Garage Entry Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-20-2011, 08:45 PM   #1
Rewards Points: 127
I have a concrete block detached garage and the entry door needs to be replaced. A frame made of 2 x 8s was installed in the rough opening, and the door is attached to one of the 2x 8 and the jamb is cut out in the opposite 2 x 8. Would it be best to install a new prehung door and remove the frame or attach a new door to the existing frame? Thanks for the help
wkumtrider is offline   Reply With Quote
Old 03-21-2011, 06:28 AM   #2
Assuning the 2x8's are not structural(not holding up a lentil or header), you could remove them and install a prehung door. Tapcons are a marvelous invention, just screw thru the shims or you will bow the jamb.
Old 03-21-2011, 06:50 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
If you remove the existing 2x8 jamb then you will have to fir out the jamb on the new pre-hung door to make it fit in the concrete block door opening.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-23-2011, 04:43 PM   #4
Rewards Points: 127
Hi, what do you mean by "fir out the jamb"?
Old 03-17-2012, 05:11 PM   #5
Rewards Points: 127
Standard prehung doors will not fit becuase the rough opening (which is concrete block) is too small. The height of the rough opening is less than 80" so a standard prehung door is too tall. It is also difficult to find an entry door without a frame.
Old 03-17-2012, 05:13 PM   #6
Framing Contractor
Rewards Points: 126
A year later and you still haven't installed a door?
sixeightten is offline   Reply With Quote
Old 03-17-2012, 05:22 PM   #7
Rewards Points: 127
Nope. I put it off and plan to take care of it this summer.
Old 03-18-2012, 01:57 AM   #8
Tool Geek
PaliBob's Avatar
Welcome back, include some dimensions and we will have another go.
Disclaimer
& Stay Safe
.....Bob Lavery
Garage Door Repair Tip doortodoor Windows and Doors 0 03-15-2011 08:05 AM
Installing steel entry door NoExperience Carpentry 2 10-23-2008 11:23 AM
garage door lock jack_j General DIY Discussions 1 12-27-2006 06:40 PM
Installing a New Entry Door Renovator Building & Construction 6 04-24-2006 09:02 PM
