Installing Full Frame Windows With Existing Metal Siding - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 02:58 PM   #1
Rewards Points: 14
Question
Installing full frame windows with existing metal siding
Hello.
I need some advice on how to install new-construction full-frame windows on my house that has metal siding.
I've been told that it is not possible to properly install full-frame windows without removing the metal siding.
I was then told that I can't remove the siding and put it back on. I would need to re-side the house--which I can't afford at this time.
How do I properly install these widnows if removing is not an option? Will I be able to weather proof the nail fin and flashings?
I do not want to use pocket windows--my sills are rotten. Currently my home has single pane double hung windows with the exterior storms and aluminum siding.
Thanks you.
testerdiyc is offline   Reply With Quote
Old 03-18-2011, 07:27 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can cut back the metal siding 3 or 4'' install your flashing and window than install some type of trim whether aluminum vinyl or wood the choice is yours,just make sure you use a competent siding installer that understands drainage details
Tom Struble is offline   Reply With Quote
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
HomeSealed (03-18-2011), kwikfishron (03-18-2011)
Old 03-18-2011, 08:19 PM   #3
Rewards Points: 14
Does flashing get installed before the window?
Old 03-18-2011, 09:38 PM   #4
kwikfishron's Avatar
Rewards Points: 228
It is not only possible it’s very doable.
It does take a little more than basic DIY skills to pull it off properly though.
Post some pictures and we can tell you how and then you can decide whether you're up to the task or not.
As Tom said the new look will have to include window trim.
kwikfishron is online now   Reply With Quote
Old 03-18-2011, 09:38 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
No, but I have to say, it really is not a diy task.... Regarding your sills, is it the full sill that is rotted, or just the outer 1 1/2" or so, which is just the sill nose and would not necessitate full replacement.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
new hardi siding and windows - what have I started? aargh! derf36 Project Showcase 51 06-11-2010 06:26 PM
Aluminum siding over existing old wood siding. timothevs Building & Construction 1 04-23-2009 05:13 PM
Can I frame exterior windows over siding? Wreckingbar Building & Construction 1 03-13-2009 06:32 PM
Sealing windows with vinyl siding bighoneydolist Building & Construction 8 03-08-2009 07:36 PM
installing full frame windows with existing siding mlmaher Building & Construction 3 09-11-2008 08:56 AM
