Installing Folding Doors On Concrete, Will Be Carpeted. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 10:15 AM   #1
Installing folding doors on concrete, will be carpeted.
I should probably allow room for carpet, so i am thinking of installing some wood blocks to set the bottom pivot points on. Should i use hardwood? Trim and doors are oak. How high? 1/"2? Would adhesive be good enough or do i have to drill anchors? Thanks?
toobhed is offline   Reply With Quote
Old 04-02-2012, 07:10 AM   #2
Wood blocks, yes, but use plywood. Naturasl wood tends to split too easily. Probably easier to do after the carpet is installed. Then you know exactly how much clearance is needed.
Old 04-02-2012, 08:00 AM   #3
DIY staff
Rewards Points: 7,174
There is a high quality bifold door hardware available that mounts to the jamb only---no floor blocks needed--very strong--sorry but I don't recall the brand off hand.
carpet and pad thickness vary a lot---and 1/2" above the carpet is needed---so gap to floor may end up 1" to 1 1/4"---Mike---
Installing en-suite shower room onto concrete floor COACHHOUSE Plumbing 4 01-03-2012 10:34 PM
Installing 9mm bamboo over 9mm wood floor and concrete hellobritt Flooring 4 08-30-2011 09:35 PM
Installing prefinished wood over concrete Beaver Handyman Flooring 13 01-03-2011 09:24 AM
Installing french doors in a load bearing wall johnsan Building & Construction 6 01-03-2009 04:59 PM
Installing New Interior Doors... Question. TPhillips Remodeling 7 12-30-2008 07:11 AM
