Installing Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-15-2014, 01:22 AM   #1
Installing doors
Do these work? http://www.homedepot.com/p/Unbranded...-201/202366685 ? They seem flimsy but would make installation pretty quick.
Or are shims and nails still the best way to go?
lk00331 is offline   Reply With Quote
Old 01-15-2014, 07:25 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Shims and nails/screws.
The Following User Says Thank You to Windows on Wash For This Useful Post:
lk00331 (01-15-2014)
Old 01-15-2014, 08:38 AM   #3
Rewards Points: 2,238
What "WoW" suggests, above!
Sometimes it's nice to go "fast" -
Sometimes it ain't!
rossfingal
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Old 01-15-2014, 08:47 AM   #4
Rewards Points: 153
I wouldn't use those. If you want fast, there are faster ways, and if you want strong, shimming is better.
eandjsdad is offline   Reply With Quote
The Following User Says Thank You to eandjsdad For This Useful Post:
Old 03-06-2014, 04:41 PM   #5
You'll still need to go through the process of securing it with shims and screws/nails and checking level and plumb, etc... Not sure if it would save that much time.
DIYRemodeler is offline   Reply With Quote
Old 03-10-2014, 09:48 AM   #6
If you are hanging doors in new construction, you might be able to use those. If you house is anything like mine (30+ yrs old), there isn't anything square about it. I just hung a knee wall door this weekend. On the hinge side, the bottom if about 3/4" out from the jack stud and the top corner is right against the jack stud.
As I have found, hanging doors teaches you to take your time and check, check and recheck for plumb. If you don't do this for a living, there isn't anything fast about it.
liquid6 is offline   Reply With Quote
Installing Used Exterior French Doors connor016 Windows and Doors 8 06-19-2013 09:01 PM
Installing French Doors in Existing Exterior Wall Aarons Windows and Doors 11 08-08-2011 02:32 AM
installing bifold doors with baseboard molding cuda719 Carpentry 1 07-04-2011 09:15 PM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 01:35 PM
Installing laminate around doors??!! RonR Building & Construction 1 12-30-2007 03:08 PM
