Installing Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 08:28 PM   #1
installing doors
do I hang my doors before I install laminate floor or can they be hung after the floor has been intalled?
MUJohnson is offline   Reply With Quote
Old 04-10-2012, 08:33 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If there's a chance the door will rub against the floor after the floor's installed I'd do the floor first then trim door if needed then hang it.
sublime2 is offline   Reply With Quote
Old 04-10-2012, 08:37 PM   #3
Rewards Points: 14,026
Are these new prehung doors, if so do the floor first then the doors.
You do know your not suppost to run laminite through a doorway and continue on into the new room, right.
There needs to be a transition strip in the center of the doorway.
Old 04-10-2012, 11:50 PM   #4
cks
Location: Whitby (just outside of Toronto), Ontario, Canada
Why is a transition piece needed at a doorway for laminate?
Just curious, since I will likely lay down laminate in the future.
cks is offline   Reply With Quote
Tags
doorway transitions , laminate flooring
Reality check on interior doors recently delivered PatBB Carpentry 8 09-05-2011 05:36 PM
Installing French Doors in Existing Exterior Wall Aarons Windows and Doors 11 08-08-2011 01:32 AM
installing bifold doors with baseboard molding cuda719 Carpentry 1 07-04-2011 08:15 PM
Installing bifold doors in a non-standard rough opening michelob Carpentry 7 05-15-2009 12:35 PM
Installing laminate around doors??!! RonR Building & Construction 1 12-30-2007 02:08 PM
