Installing A Door Where There Was No Door... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 08:29 PM   #1
Installing a door where there was no door...
Hey there! I hope someone can help me with this... I own a mini home and would like to install a door between my kitchen and my living room. What I'm basically wondering is, can this be done if there was no door there previously, just an opening? Would the walls of the mini home be able to support a door and frame? Any advice would be greatly appreciated :-)
uprooted_caper is offline   Reply With Quote
Old 05-02-2011, 08:29 PM   #2
Framing Contractor
Rewards Points: 120
What exactly is a "mini" home?
sixeightten is offline   Reply With Quote
Old 05-02-2011, 08:34 PM   #3
Hmmm... I guess mobile home is what you might call it? It's not a trailer exactly, but a pre-fab mini home. It's 16x72 ft. Here is a link to one which is similar to mine.
http://www.google.ca/imgres?imgurl=h...ed=0CE8Q9QEwBA
Old 05-02-2011, 08:38 PM   #4
Framing Contractor
Rewards Points: 120
You should be able to do that. Check the opening width and height. The wall thickness may come into play as well, but there are ways to deal with that. The wall will be plenty strong enough for the door if thats your question.
The Following User Says Thank You to sixeightten For This Useful Post:
uprooted_caper (05-02-2011)
Old 05-02-2011, 08:40 PM   #5
the Musigician
DangerMouse's Avatar
Modular maybe? How thick are the interior walls? If they're 2x4, there shouldn't be a problem.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 05-02-2011, 08:40 PM   #6
That is my question, thank you. Have you ever done this before? Any advice you care to pass along? The ceilings are 7.5ft tall and the opening is 42inches. Above all my other doors, there is about a half foot of wall between the top of the door frame and the ceiling. How would I go about constructing that?
Old 05-02-2011, 08:47 PM   #7
Framing Contractor
Rewards Points: 120
At 42" wide, you will have to fill in one side with framing and drywall. You will probably use a door that is 30 or 32". This will take some light carpentry skills. Drywall will need to be taped/finished, walls painted, door set and trim applied.
Tags
door , frame , mini home
Installing exterior door 99miles Carpentry 11 03-30-2011 06:01 AM
Pre-Hung doors - How to Hang Willie T How To Guides 23 01-28-2011 09:24 AM
Installing Door at end of hallway lofar Remodeling 3 05-05-2009 11:47 AM
Installing a Door in an existing pass-through gbarron1 Building & Construction 2 03-17-2005 03:47 PM
