Installing 1" Of Insulation On Outside Of House Need Advise - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 11:37 PM   #1
installing 1" of insulation on outside of house need advise
What do you do with the windows and doors
trent2 is offline   Reply With Quote
Old 02-04-2012, 11:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,592
Are the windows stay as is or are you removing them and replacing them?
http://www.greenbuildingadvisor.com/...foam-sheathing
Old 02-04-2012, 11:45 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Why are you installing 1" of insulation on the outside anyway?
What are you trying to accomplish?
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-05-2012, 12:16 AM   #4
Andy.
Andy,
Depending on the climate location, most folks will use 1" of exterior foam to air seal the outside wall and thermally break the stud wall from outside.
I wish there were more non-oil based alternatives out there right now but there just aren't that many right now.
2012 is supposedly specifying this stuff now. Wonder what foam lobbyist earned his pay this time.
Old 02-05-2012, 12:25 AM   #5
AndyGump's Avatar
Rewards Points: 684
Thanks Wash. actually I understand the over-all reasoning for doing this if the house in the original construction stage. But the OP is going to remove existing siding and I am wondering what the rational is behind doing that.
There are much more cost effective and less labor intensive ways of adding insulation to existing walls if that is what he is trying to do.
Andy.
Old 02-05-2012, 08:17 AM   #6
Absolutely correct. I would make zero sense to remove existing siding that is otherwise okay to put up rigid foam.
If the poster is replacing the siding though, this is an ideal time to make the home much more efficient and air tight. Foam backed siding does about 1/50th of what it promises as compared to cladding the entire home in a rigid foam board.
Old 02-05-2012, 08:20 AM   #7
Rewards Points: 13,694
Trent what's on the outside of the house now?
Is this a block home?
Old 02-05-2012, 09:52 AM   #8
Sorry I should have made it more clear, I live in Canada and this is an older house so i do need more insulatiion. My siding should have been replaced 10 years ago but wasn't and the windows are ok about 4 years old. I am looking to achieve a thearmol break and then new siding.
Old 02-05-2012, 10:15 AM   #9
What kind of siding do you have now?
How thick are the walls?
What do you have now for insulation?
Old 02-05-2012, 10:37 AM   #10
Before vinyl siding was introduced there was a particle board siding that is the stuff. My walls are 2x4 with pink insulation R12
Old 02-15-2012, 11:28 PM   #11
Still need some advice on the original question
Old 02-16-2012, 02:42 PM   #12
What is the exterior trim around the windows currently?
Old 02-16-2012, 10:52 PM   #13
Registered User
Rewards Points: 5,514
http://www.greenbuildingadvisor.com/...-outie-windows
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
trent2 (02-21-2012)
Old 02-21-2012, 09:38 AM   #14
The exterior is 1x4's, and the windows are flush to the outside wall.
Old 02-21-2012, 10:23 AM   #15
That is an easy build up then.
Are you doing new windows or have them been done?
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 10:09 PM
Installing plywood or chipboard over 1X6 planking on a 52 year old house' roof. JBfromSD Roofing/Siding 2 09-20-2010 10:09 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
