Install Storm Door With Aluminum Covered Jamb - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 02:57 PM   #1
Install storm door with aluminum covered jamb
A couple of years ago I had my house resided, and the window and door trim were wrapped in aluminum coil.
One storm door was removed and not replaced. Now I'd like to install a replacement.
Is there any way I can install a replacement storm door and when the jamb is wrapped in aluminum?
jfklein13 is offline   Reply With Quote
Old 04-16-2013, 05:04 PM   #2
Rewards Points: 13,300
No way to know without at least a picture.
We have no way of knowing how it was wrapped.
Most often if it was done right you can just go right over it.
Old 04-16-2013, 05:46 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. You generally install over it, but it really depends on whether they wrapped it with the possibility of installing a storm in the future or not.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-16-2013, 06:08 PM   #4
Rewards Points: 2,238
We install storm doors; over doors that have been wrapped - all the
time.
Hopefully, you won't have a problem!
rossfingal is offline   Reply With Quote
Old 04-19-2013, 12:57 AM   #5
Will post photos once the rain lets up.
Now that I look at it again, there is a spot where the aluminum stops, then the wood is exposed. Photos are essential.
Tags
door installation
Install storm doors ourselves, or pay to have it done? Beth777 General DIY Discussions 14 09-02-2008 04:55 PM
Correct way to install aluminum window casing? DavesHammer Remodeling 7 01-16-2008 01:39 PM
any instructions on how to install aluminum porch enclosure? brisk Building & Construction 2 12-14-2007 07:01 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
