Install Quote - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 06:58 PM   #1
Rewards Points: 874
Install Quote
Got a quote from a guy today to replace two wood windows that are about 33x51 with two new construction windows that are 45x55. He explained about building a new frame and header etc.. He quoted me $350 for install per window plus materials. Is this high?
Mstrlucky74 is offline   Reply With Quote
Old 02-26-2013, 07:13 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
If he is a quality installer, I would say he is cutting himself very short on price.
Even if your siding is just wood or vinyl.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 02-26-2013, 07:18 PM   #3
Rewards Points: 874
Andy.
Wow okay thanks. The window and door place I bought the windows from said(even with quoting ME the price of the window) it should be about 150-200 per window. IDK
Old 02-26-2013, 11:06 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I'd have to agree with the above comments. I've seen some conflicting info in your posts across the various boards, so I want to be sure that im understanding the situation accurately. If you are talking about re- framing and finishing of an opening, that is not too far off from a " cut- in " which can run run $500 to $1000 plus. Your numbers of $150 to $200 should cover a standard install, but when you are enlarging the size of an opening, that takes a job from 1 to 2 hrs each, to half a day each or more depending on circumstances.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Mstrlucky74 (02-27-2013)
Old 02-27-2013, 06:45 AM   #5
Rewards Points: 150
Agreed home sealed
kaschmid3 is offline   Reply With Quote
Old 02-27-2013, 08:39 AM   #6
Rewards Points: 12,802
Did the company giving you that price having all the info and come to see the job? Or just sit behind the deck and shoot there self in the foot by guessing and trying to low ball the other company?
Old 02-27-2013, 09:25 AM   #7
Rewards Points: 874
Wink
He was the guy selling the Soft lite windows to me.....he was aware of the new frame needed and header... But on the phone
Old 02-27-2013, 12:58 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Nothing wrong with a range or "ballpark", put certainly a site inspection would be necessary for an accurate price.
www.HomeSealed.com
Looking for help on how to install recessed soffit. Snoopy_ Roofing/Siding 2 09-04-2012 04:45 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 06:46 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 01:35 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
