Install A "prehung" Door Sans Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-07-2013, 03:27 PM   #1
DIYer
Rewards Points: 93
Install a "prehung" door sans door?
I put in my first prehung door last year and frankly, it was a *****. Im tasked with installing another exterior door and this time it seems easier to just take the door off its hinges and mount the frame only. Seems easier to plumb it up. Do people do this with prehungs? Kosher? Just wondering
dwoloz is offline   Reply With Quote
Old 10-07-2013, 04:35 PM   #2
Rewards Points: 13,750
Nope, never!!
First thing you'll find is the knob will not line up with the latch doing it that way.
If your having that much trouble then your doing something wrong.
A lot of it is in the prep work. The rough opening needs to be square and plumb, the floor area needs to be checked for level, if it's off it's going to throw the whole door install off.
Old 10-07-2013, 04:41 PM   #3
DIYer
Rewards Points: 93
Originally Posted by joecaption View Post
Nope, never!!
The problem with the last one (Masonite from Home Depot) was quality control was terrible; it just wasn't put together well. The hinges weren't fit correctly. This time its a JeldWen which probably isn't much better
Old 10-07-2013, 09:01 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,214
hanging a exterior door solo is tricky because its near impossilbe ot keep the door tight to the wall while shimming without the door falling out of hte opening
woodworkbykirk is offline   Reply With Quote
French Door Install Question Zap Applewood Building & Construction 4 10-24-2011 09:52 PM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 09:00 PM
How to install wood screen door and exterior steel door orange Remodeling 2 07-16-2010 12:00 PM
New exterior french door install in a stucco wall lightninrodman Building & Construction 2 06-30-2007 11:08 AM
