Install Pre-hung Exterior Door In Cinder Block - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-15-2013, 02:22 PM   #1
Rewards Points: 20
Install pre-hung exterior door in cinder block
I'm replacing a probably 60 year old interior door hung on an exterior 8" cinder block wall...garage! So its a side door 24 x 80.
The pre-hung door overall frame width is 25.5 x 81.75. The opening is 27.5 x 82.00...yeah tight on top. I'm going with a 6 9/16" jamb width which is what is currently in placee. But my concern is how best to frame the cinder block wall and with pre-treated lumber?
I have 2 inches to play with on the sides and if I did 3/4" on each jamb, I still have 1/2" to play with. Probably the best part...it all looks pretty plumb.
So how best to approach this?
hunt4cleanair is offline   Reply With Quote
Old 08-15-2013, 03:31 PM   #2
Rewards Points: 6,652
If you use Pressure Treated 1x4's, you have no space for hanging that 24" door. The min. size of an entrance door should be no less than 30", preferably 32", 36" at the max for a main or rear entrance.
Even most bedroom doorways are 30-32 inch openings in majority of homes. Personally I would cut out the opening with a concrete saw, then put in a Lintel at the top, and rough in new framing for the doorway, so that you can get a 32" door in there.
Post pictures of this.
Old 08-16-2013, 04:33 PM   #3
Rewards Points: 20
Checking today, the actual width of a pressure treated 1x4 is 3/4" which with two, gives me 1/2" play. Am I missing something here?
Old 08-16-2013, 05:43 PM   #4
No you are not. Still you should get that opening to at least a minimum of 32". 24" is just way too tight for proper use, or egress.
The Following User Says Thank You to gregzoll For This Useful Post:
Windows on Wash (08-16-2013)
Old 08-21-2013, 03:34 PM   #5
How many openings are in the room?
For egress you need 2. A garage door is considered one, a door back into the home is technically 2.
I agree, a bigger opening is ideal, but if you can't/won't then here is my suggestion.
Plumb the hinge side with 1x6 pressure treated wood, then hang the door. for the latch side, slip in a 1x, or shim it depending on your spacing left.
You are going to have to attach the door with tapcons on all sides because a 1x isn't thick enough to hold the door in place.
hungryjack is offline   Reply With Quote
drywall over cinder block smitty1960 Drywall & Plaster 6 11-14-2010 09:47 AM
building concrete steps cinder block frame? drewhart Building & Construction 2 06-10-2010 02:48 PM
Cinder block home ibrrhobo Building & Construction 9 08-20-2009 08:05 AM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
How to install belgian block? Tmb9862 Building & Construction 2 09-19-2008 05:50 PM
