Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-27-2011, 09:17 PM   #1
Instal storm doors on a vinyl door frame
I have a double front metal doors with lites on both sides and a transom above. I am looking to install double all glass storm doors. I had a big box contractor come and take a look and was told the door frame is hollow vinyl - so they would not install storm doors and the vinyl frame is not strong enough. Are there any options to reinforce the door frame or possibly a kit to allow storm door mounting?
iamca is offline   Reply With Quote
Old 10-28-2011, 11:57 AM   #2
Exterior Construction
Windows on Wash's Avatar
Most of the support of the doors is at the jambs where there should be some wood somewhere.
The non-structural parts can be attached to the door but be sure to pre-drill the holes or it will crack the vinyl.
The Following User Says Thank You to Windows on Wash For This Useful Post:
iamca (11-10-2011)
Old 11-10-2011, 10:58 PM   #3
Question
Sorry it took so long to respond. There is wood at the door jamb but that's the extent of it. Beyond that on the outside is 5 inches of vinyl or PVC frame.I did some "exploratory" drilling and research and I attached a drawing. I now believe the correct term for this material is multi-chamber vinyl or pvc. So without any wood or metal close by is this PVC frame ok for mounting and supporting storm doors? If so - what type of screws would I use? And the last question is should I use screws long enough to hit more the one of the "chamber walls"? Appreciate any advice here.
Old 11-10-2011, 11:22 PM   #4
The attachment didn't show up on my last post
Old 05-19-2012, 07:01 PM   #5
so what did you end up doing?
bourne78 is offline   Reply With Quote
Storm Doors benchmarkman General Discussion 6 07-14-2010 09:39 AM
Install storm doors ourselves, or pay to have it done? Beth777 General Discussion 14 09-02-2008 04:55 PM
Painting Vinyl Sliding Glass Doors IdahoBob Painting 5 01-05-2008 05:34 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
