Initial Questions On Brick Work - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-29-2013, 09:28 PM   #1
Rewards Points: 154
Initial Questions on Brick Work
Hello,
I have a window in a wood-framed room with brick veneer on the outside (room is in the half underground part of a split-level). Having re-done the room, I found that the window header was placed at the top of the wall and framed (use that term loosely) down to the window. We have decided to put a taller window in up to the header about 10" higher than original window top. It will be a vinyl replacement window.
I have to raise the lintel up to the bottom of the highest course that covers the header and size/frame the window accordingly. The window is at the back of the house so I'm okay with just cutting the brick but need some advice on how to approach it. Then I would remove mortar to install the new lintel finishing off with mortar, capping, and caulking.
Can anyone provide some advice on the brick work? I've been looking for a resource specificly geared to increasing the height of a window with no luck.
Thanks for any help.
Pete
pete0403 is offline   Reply With Quote
Old 10-29-2013, 09:52 PM   #2
Rewards Points: 12,858
Anyone else feel a replacement window is the wrong style window for this and likely to leak.
Old 10-29-2013, 10:04 PM   #3
Rewards Points: 154
I think it's what is there now....no evidence of leaking seen when the wall was opened.
Inside pics to help: (full view, left side where window meets frame, top of window with insulation in gap between window and header)
Old 10-30-2013, 06:46 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
You pretty much have it figured out but I don't think attempting brick work is the best idea as a starter for most folks.
Old 10-31-2013, 10:31 PM   #5
Rewards Points: 154
Okay. I'll get someone experienced with brick work to help me through this one so I can learn. Thanks.
Old 10-31-2013, 10:55 PM   #6
Concrete & Masonry
Rewards Points: 470
I've done hundreds of tooth-ins for window/door replacement in brick and stone veneers in the past. You don't necessarily need to have the lintel fall on a full course, you can have a ripped brick under the lintel and stand cut soldier (vertical) brick on the lintel to get back to coursing above.
The most important element of making this a successful/leak free installation IMO is to ensure you flash the top of the window, as well as the angle iron correctly. A few weeps on the angle iron would be beneficial as well........
jomama45 is offline   Reply With Quote
Old 12-08-2013, 01:59 PM   #7
Rewards Points: 154
To update this thread. I got an experienced guy (my dad) to do it for more while I helped/watched. I think I could try something like this myself with guidance next time if it ever came up again.
It worked out that the lintel moved up to a full course of bricks so that made things much easier. He flipped the lintel around so it looks new and toothed in where necessary. It honestly looks now like the brick was original that way.
Thanks feet the advice.
Old 12-09-2013, 07:01 PM   #8
Rewards Points: 894
Glad to hear you got it figured out and done.
Hopefully you fed your Dad for his labors at a minimum.
Old 12-20-2013, 08:57 AM   #9
Rewards Points: 154
Fed and "watered" :-D
wrought iron security door frame diy888 Windows and Doors 6 02-22-2016 08:08 AM
Exposed Interior Brick Questions FClef Building & Construction 4 05-05-2013 10:10 PM
Brick veneer is 4 rows below grade- redo or leave? cbrc5eric Building & Construction 11 12-27-2011 09:09 PM
Possible Non-Permitted Work with violations - New Purchase - Questions for my friend jamiedolan Electrical 9 12-03-2011 11:55 AM
Brick work to repair a Chimney worthspending Building & Construction 2 10-17-2010 08:58 AM
