Impact Sliding Glass Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 12:53 PM   #1
Rewards Points: 12
I just replaced an old sliding glass patio door with an impact slider made by TM Windows here in South Florida. I did a water test and was surprised that even though the frame is square, and everything fits securely, water penetrates the weather strip at the base of the door panel, and fills the track - on the inside of the door panel. Assuming that something was wrong, or missing, I had a guy from the company come out, and he told me that this is the way the door is supposed to work - that the water will eventually drain out to the exterior via a series of gaps at either end of the tracks on the sill that act as weep holes. There is a high rail (3") at the interior edge of the sill that prevents the water from draining to the interior.
I have never seen a door design that actually allows water to enter the interior of the house, and frankly I wouldn't have made this change if I had known this. Is this the way the new sliders are designed? I bought 2 doors - I haven't installed the other, it is definitely going back.
pianodude is offline   Reply With Quote
Old 09-07-2012, 01:42 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
never heard of such ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-13-2012, 05:58 AM   #3
Rewards Points: 12
Here is a video I made of the water intrusion. I think it's pretty unbelievable.
http://www.youtube.com/watch?v=t4lh6...e_gdata_player
Old 09-13-2012, 06:20 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
No door (especially a slider) will be water tight at the interface between the track and the panel.
As long as the sill is a full welded and/or sealed sill, that water should be draining out of the door via weep holes at the bottom of the frame.
Does the door/sill have some positive pitch to outside?
Old 09-13-2012, 11:50 AM   #5
Rewards Points: 12
I have several doors in my home, including 2 old sliders. They all
seal tight, no water inside, even in tropical storms and hurricanes.
There is no positive pitch on this door. I set it level in wet cement according to the directions.
If you watch the video, you can see that the water does drain to the outside. The fact that it comes into the interior and fills the sill on the negative side of the door panels first is what bothers me. Just a light sprinkling from a garden hose puts about 3/4 inch of water in the sill - its like a rain gutter, water comes in and flows out. When I turn the hose off, or when it stops raining, the water drains outside. As long as it is raining, the inside of the sill is full of water. It seems that a strong wind blown rain could overwhelm this system.
I could tolerate a few drops, but this is a lot of water. This is a bedroom btw. Any time it rains (as it does a lot here in Florida) my son is sleeping next to a trough of rain water.
Old 09-13-2012, 03:36 PM   #6
Bombastic Idiot
notmrjohn's Avatar
i think i what kinda "..." you're talking about.
Dude, that just ain't right. What if its raining faster than the water can get out? And it takes 2 hours to drain? Call the company again, tell um to send out somebody who knows something about the products they make.
Windows, you're correct about being absolutely water tight, even submarines aren't absolutely water tight. But that was ridiculous.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-13-2012, 04:33 PM   #7
GBrackins's Avatar
notmrjohn,
it might come with an emergency pump for those cases where the inflow is greater than the outflow ....
Gary
Help with sliding glass doors. ob2s Windows and Doors 8 05-30-2012 08:54 AM
Sliding Glass Closet Doors newhome2 Interior Decorating 6 11-02-2010 12:42 PM
Installing 16ft sliding glass impact door dario08 Building & Construction 1 09-29-2010 06:00 PM
Replacing Sliding Glass Door w/ French Doors zapatero3 Remodeling 1 07-15-2010 05:01 AM
Sliding Closet Doors & Base Trim HangGlide Carpentry 4 03-26-2010 10:09 AM
