IGU Replacement In Aluminum Window Frame - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 06:57 PM   #1
Question
IGU replacement in Aluminum window frame
I have a failed IGU (insulated glass unit - dual pane) in an older aluminum window. I have another good IGU (from another spare frame) that I wish to substitute for the failed unit.
When I try to separate the IGU from the frame it is stuck to it by a black sealant. I tried using a breakoff knife and putty knife but they don't work.
Without breaking the IGU, what is the best way to release the glass unit from the aluminum frame?
Daler is offline   Reply With Quote
Old 09-14-2011, 09:58 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
There are special tool for cutting the glazing bead (looks like a pizza cutter), otherwise, you can also get extra-long (like 4") utility blades that can be used in any regular knife.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 09-15-2011, 09:42 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Wear leather gloves without fail and perhaps some sleeve coverings. Very easy to hurt yourself if you are not careful.
Aluminum replacement window sources?? clone477 Building & Construction 6 02-05-2012 01:46 AM
Installing window AC in metal frame sato HVAC 10 08-08-2009 10:15 AM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 09:24 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
Window Frame Materials - Vinyl vs Aluminum vs Fiberglass chrison600 Building & Construction 2 10-09-2005 12:13 PM
