Identify Balancers - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 05:28 PM   #1
jam486's Avatar
Identify balancers
I am moving to a new house and must replace sash balancers on some windows I have been unable to identify the windows or balancers. the only identifying marks on the windows that were installed in the mid 70s are these numbers and letters etched on the metal strips between panes, CARAD SSB-2-74 SIGMA 114. the balancers are about 25" long with a plastic tube and a long spring inside.
Identify balancers-window-balancers-001.jpg   Identify balancers-window-balancers-002.jpg   Identify balancers-window-balancers-003.jpg
jam486 is offline   Reply With Quote
Old 07-29-2012, 06:34 PM   #2
Rewards Points: 6,652
Probably will not find that gadget anymore. Any info on the windows, such as a manufacturer plate? Cheap windows come with cheap parts. This home is not by chance in a large scale tract community, or one of the manufactured type homes, that they would truck the walls on site already completed, then assembly on site.
Old 07-29-2012, 07:10 PM   #3
jam486's Avatar
No there was no other info on the windows. The windows are in a 1974 addition added to a 1840s Greek revival house. Further research has shown the windows may be from a company called Caradco. It seems they were sold in the 70s as a less expensive alternative to Andersons etc. The tube is approx. 5/8" in diameter and there is a corresponding round groove in the sides of the sash. If I cannot find replacements I may be able to use a more modern spiral balance.
Old 07-29-2012, 09:18 PM   #4
I would try to use a alternative replacement, that can stand up. Also, almost 40 year old windows means that they are not going to be the best air sealed windows, and at this point may need to be updated to better window units, that can help keep your heating and cooling bills down, plus have better hardware that can be replaced if it breaks down the road in 20-30 years, than something that is throw-away.
The Following User Says Thank You to gregzoll For This Useful Post:
jam486 (07-30-2012)
Old 07-30-2012, 06:40 AM   #5
jam486's Avatar
Thanks for response, You are right about the air leaks, at some time outside storm windows were added. They must stay for a while due to priority of projects. Due to a Rainy day here in Maine I was able to finally identify them. They seem to be carried by Strybuc industries in their obsolete section. I will call them today and ask about price and availability. The windows were made by Caradco. The price will determine if I use them or modify the windows.
Old 07-30-2012, 08:43 AM   #6
I keep our storms closed when the windows are closed. Helps to keep the house cooler during Summer, with the a/c running.
Old 07-31-2012, 10:35 AM   #7
jam486's Avatar
We do not need AC here in Maine to often, but when I do use it I close storms. I found the balance I needed, but because they are obsolete they cost $25 to $32.50 per balance. Caldwell manufacturing makes a spiral balance conversion kit for 1/2 that price so it looks like conversion is a viable option.
Please help identify this stem denbarg Plumbing 1 07-28-2012 10:51 AM
Please help me identify this tile jsoldatot Flooring 4 04-29-2012 08:47 PM
Help me Identify this paint color? xhayatox Painting 14 03-27-2011 01:57 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
