Ideas On Sliding Door Needed - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 08:53 PM   #1
Ideas on sliding door needed
In my basement I have a pool room. THere is no door to get in and out from the corridor. The opening is 80in wide by 78 high.
I want a door thick enough to block sound and want something with a nice look. I have a lot of wood in the pool room so I'd like to maybe build wood sliding doors.
Any ideas on what I can do? The opening is 78 high but if i hang it just outside the opening, the corridor's ceiling is 84
Should I do one big door? 2 or 3?
What kind of rails should I use?
Any door ideas I could build?
thanks for any idea you might have
lange74 is offline   Reply With Quote
Old 01-02-2012, 09:18 PM   #2
Rewards Points: 13,296
Sliding dorrs are not going to block sound.
Old 01-02-2012, 10:03 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
I will respectfully disagree with Joe in this particular instance.
We currently use a SGD that has a 4 mil thickness glass that is like closing a vault door compared to other SGD. I have one in my office and you can't hear anything through it when closed and it appears (as unscientifically as possible) to block about as much sound as the walls (2x4 metal studs and drywall with no insulation).
Old 01-02-2012, 11:58 PM   #4
In a little over my head
Rewards Points: 706
We replaced a sliding glass door with a double French Door. Nice look, open or closed.
ratherbefishing is offline   Reply With Quote
Old 01-03-2012, 04:25 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I would have to agree with WoW, although perhaps what Joe was referring to was a custom built diy door? .... It is unlikely that you'll be able to build anything that seals well enough to significantly block sound unless you have some serious skills.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Loft bedroom ideas! Help! Alexz7272 Interior Decorating 5 12-31-2011 10:10 PM
Redecorating DD's room....thoughts, ideas? Looong. RealHouswifOfOK Interior Decorating 14 04-22-2011 07:19 PM
Loo9king forward to ideas nanalane9 Introductions 3 03-25-2011 09:07 AM
Condensation on baseboard by sliding doors... Donmills Flooring 0 06-28-2010 09:35 PM
Ideas needed for kitchen reno (pic included) bearcats23 General DIY Discussions 5 05-24-2010 09:36 PM
