Ice On Window Frame - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-15-2014, 09:43 AM   #16
Rewards Points: 109
[QUOTE=Fairview;1306061]
... as double pane windows are made, using a low conductive gas such as Argon to bring the dew point temperature down in the -35F range.
[QUOTE]
Not precisely.
While you are 100% correct that it is absolutely necessary to keep the dew point temperature as low as possible inside of the IG airspace to prevent the airspace from frosting up when it gets really cold outside, the gas infill is primarily intended to slow down convection currents within the airspace in order to keep the inner lite warmer (which certainly does lower the potential for condensation on the glass of course).
In order to lower the dew point between the lites down to the -35F range, IG's are manufactured with desiccant as part of the spacer system resulting in the ultra-dry airspace needed to prevent condensation inside the space in normal operation.
oberon is offline   Reply With Quote
Old 02-15-2014, 11:27 AM   #17
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,790
Like you know what you are talking about....
Old 02-15-2014, 11:53 AM   #18
Rewards Points: 109
what part?
Slanted window - should I correct? miamicuse Windows and Doors 11 04-16-2013 06:59 AM
Rental - Warped Frame, Window Locking Issues tuffluck Windows and Doors 8 12-21-2012 10:01 AM
basement window frame paint? s002wjh Painting 8 12-25-2011 01:06 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Peeling Paint in Window frame duffeymt Painting 3 09-07-2008 10:52 PM
