Hurd Window Replacement Glass - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-01-2012, 01:47 PM   #1
Hurd window replacement glass
How do I replace the glass in my 20 year old hurd windows?
Linda Neveaux is offline   Reply With Quote
Old 04-01-2012, 08:16 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
1. If you have Hurd windows that are 20 yrs old, then you have outlived the life expectancy of that window, so it is probably time to replace. 2. If they are somehow still in good shape, you'd be well advised to call a glass shop for replacement as their labor charge is typically very reasonable. 3. If after point one and two you are still looking to replace the glass diy, there will be either a vinyl or wood glazing bead that is removable.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-02-2012, 07:06 AM   #3
Contact Hurd, it may be under warranty, or they can make suggestions for replacing it.
Old 04-02-2012, 07:23 AM   #4
Rewards Points: 2,516
If you have the double hung windows with compression side balances Hurd makes a replacement sash kit.
The kit includes two new sashes(with new Low-E insulated glass and dual intercept spacers) and new jamb liners.
http://www.hurd.com/pdf/professional...er_Install.pdf
hammerlane is offline   Reply With Quote
Old 04-02-2012, 07:32 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
Is that the only thing wrong with them? Do they leak air? Is there any rot?
Most folks don't keep 20 year old Hurd windows. They are not historic and usually not up for retrofitting as the bones of the windows aren't worth saving.
looking for some help picking a replacement window: prm2003 Windows and Doors 21 03-22-2012 09:07 PM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 11:21 AM
Weight of Glass Block Window jonathan03 Remodeling 2 06-23-2010 11:21 AM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
