-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Hurd window replacement glass (http://www.diychatroom.com/f104/hurd-window-replacement-glass-138926/)
Linda Neveaux 04-01-2012 02:47 PM
How do I replace the glass in my 20 year old hurd windows?
HomeSealed 04-01-2012 09:16 PM
1. If you have Hurd windows that are 20 yrs old, then you have outlived the life expectancy of that window, so it is probably time to replace. 2. If they are somehow still in good shape, you'd be well advised to call a glass shop for replacement as their labor charge is typically very reasonable. 3. If after point one and two you are still looking to replace the glass diy, there will be either a vinyl or wood glazing bead that is removable.
Just Bill 04-02-2012 08:06 AM
Contact Hurd, it may be under warranty, or they can make suggestions for replacing it.
hammerlane 04-02-2012 08:23 AM
If you have the double hung windows with compression side balances Hurd makes a replacement sash kit.
The kit includes two new sashes(with new Low-E insulated glass and dual intercept spacers) and new jamb liners.
http://www.hurd.com/pdf/professional...er_Install.pdf
Windows on Wash 04-02-2012 08:32 AM
Is that the only thing wrong with them? Do they leak air? Is there any rot?
Most folks don't keep 20 year old Hurd windows. They are not historic and usually not up for retrofitting as the bones of the windows aren't worth saving.
