How Should I Seal This Window ? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 03:13 PM   #1
Rewards Points: 236
how should i seal this window ?
see the first pic. that is my sheathing and siding. the sheathing slots have some type of mortar filling the slots. not an ideal situation, when looking to seal.
2nd pic is the window in its new home. but not completely installed.
now. sealing the window to the sheathing. can i use coil stock ? or, that sealing tape that menards has ?
http://www.menards.com/main/doors-wi.../p-1456264.htm
my plan is to use boards that i already have, and cut them to fit(as seen in the 2nd pic) then caulk & paint.
then, sometime in the next year, all new siding over all of this.
btw, the brown boards you see. that is where i had to frame out from the old window.
how should i seal this window ?-img_1809.jpg   how should i seal this window ?-img_1810.jpg
Fix'n it is offline   Reply With Quote
Old 08-05-2012, 05:01 PM   #2
Rewards Points: 6,652
Looks like Plaster & Lathe to me.
Old 08-05-2012, 07:58 PM   #3
Rewards Points: 236
yeah it does, on the outside. the inside it looks just like regular tongue & groove.
anyway. my issue is that there is no house wrap of any kind. and because a few pieces of the mortar have fallen out, its not completely smooth. but it is pretty flat.
Old 08-05-2012, 08:09 PM   #4
Rewards Points: 14,026
What's the grand plan to do with that siding. It sure looks like old asbestos siding that's no longer made.
No nailing fin on the window?
Old 08-05-2012, 08:42 PM   #5
Rewards Points: 236
the plan is to put foam board right over the top of it. then whatever siding i choose. so i don't much care how what i am doing now looks, as i will be going right over it someday. but i do need it to function well.
yes, they do have fins, new construction. the boards covering them, i just threw them up there for a little protection, until i have this resolved. you can see the bottom fin on the cedar. that cedar is there to take up the space as sheathing.
that is not the planned finish.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
