How To Replace Mobile Home Window Glass? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-19-2012, 03:11 PM   #1
Exclamation
How to replace mobile home window glass?
Some punk kids threw rocks at my windows and broke out seven of them. I cant wait on this, because the rain is already making my particleboard floors warp and bend and they are so weak i had to move out all of my furniture. They are quite large windows, single pane with aluminum frames. I cannot figure out how to open the frames to remove the old glass and insert the new glass. Please help me!
firsttimeremode is offline   Reply With Quote
Old 07-19-2012, 04:21 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 200
Some of those windows are screwed together at the corners some have plastic trim which clips in from the outside. Either way most of that glass is held in place with Butyl caulk which is kinda like a soft bubble gum. Butyl caulk doesn't completely get hard but it will sure hold the glass inplace. The only way I know of to get the glass out is heat the glass around the edges and slowly pull it loose. Clean as much as possible of the old caulk out and especially any glass particles, caulk the frame install the glass into the wet Butyl install screws or trim.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
firsttimeremode (07-19-2012), Windows on Wash (07-19-2012)
window unit ac not cooling properly in mobile home p5200 HVAC 9 07-05-2012 01:52 PM
Glass block window in tiled shower stall ddmcc Windows and Doors 16 01-04-2012 11:48 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Replace window in shower with glass blocks organick Kitchen & Bath Remodeling 6 10-10-2009 10:45 PM
