How to remove the Semco channel channel balance.
If I recall, the plastic of the balance unit just snaps into a kerf in the wood. That said, I've never removed them with the intention of saving them, only during window replacement... As Joe suggested, contacting the manufacturer for instruction would probably be the best course of action if you are worried about damaging them during the removal.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
