How To Remove The Outside Sash On A PELLA Window To Replace A Broken Glass - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-15-2013, 02:31 PM   #1
how to remove the outside sash on a PELLA window to replace a broken glass
I have Pella windows from around 1985 with blinds in them. The outside glass is broken and I need to remove the outside part to replace the glass. I want to do it right and not just guess. Please help.
sylvia43551 is offline   Reply With Quote
Old 08-15-2013, 02:35 PM   #2
Rewards Points: 6,652
Post pictures of what you are dealing with. If it is the storm, you usually have to open up the inside window, then the unit will swing in, when you release it from the channels. If it is the actual window itself, it would be removed from inside the house.
Is this a double hung Sash, or Single hung opening window? What is the model # on the plate that is on the window? A local glass company will usually come out and pull the unit, replace the glass on site sometimes. Check around and get some quotes, and let the experts deal with it.
The best thing to do if you want info, is go to http://www.pella.com/support-center/...y/default.aspx Also Pella has experts licensed by them in almost all areas, use their locate at the bottom of that page, to find someone that Pella allows to do work and will warranty it.
Old 08-15-2013, 05:34 PM   #3
window pics
pic of window and inside bottom
how to remove the outside sash on a PELLA window to replace a broken glass-window-004.jpg   how to remove the outside sash on a PELLA window to replace a broken glass-window-001.jpg
Old 08-15-2013, 07:46 PM   #4
Casement window, you have to remove those arms, and then you will be able to detach it from the hinges on the left. Contact Pella at the link I posted, and they will have like I stated, one of their licensed reps contact you, have the window replaced in no time, vs. taking it into a glass shop and waiting a couple of days to go pick it back up.
Plus they will go through and lube the mechanisms, replace any parts missing or broken if you put that in the work order.
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
Problems with Pella ProLine double-hung breaking when clenaning jpsmith Remodeling 5 04-15-2009 12:09 PM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
Double-paned window glass replacement maximizer Building & Construction 5 08-18-2008 12:06 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
