How To Remove Closet Sliding Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 08:58 PM   #1
Rewards Points: 71
how to remove closet sliding doors
One of my rooms' closet sliding doors is not sliding much at all. I think the door hardware is grinding on the sliding tracks.
I am unable to remove the doors. Please tell me how to remove the doors? Thank you.
Picture 1 is the sliding closet doors, the front panel is having problem sliding
Picture 2 is the view from inside the closet of the lower sliding door hardware on the bottom track
Picture 3 is the view from inside the closet of the upper sliding hardware on the top track.
Thank you for your advice.
how to remove closet sliding doors-dscn3310.jpg   how to remove closet sliding doors-dscn3311.jpg   how to remove closet sliding doors-dscn3312.jpg
young707 is offline   Reply With Quote
Old 07-14-2013, 09:02 PM   #2
Rewards Points: 12,794
Most likely there's dirt in the tracks. Did you try vacuuming them out?
The Phillips head screws need to be backed out to remover the whole door. Back them out and just lift up on the door.
Old 07-14-2013, 10:44 PM   #3
DIY staff
Rewards Points: 7,174
That's a Stanly, I'll bet---Just lift it up to remove it---the top screws are the hangers--tighten the screws lifts the unit to clear the track if it is rubbing on the floor plate.
Old 07-15-2013, 02:20 PM   #4
Rewards Points: 71
Yes, I check and clean the bottom track. Its seems OK. Cannot lift it.
What do you mean backed out Philips head screws. Do you mean upper of lower screw heads? I tried both clockwise & counter-clockwise, it just keep turning.
Old 07-15-2013, 06:43 PM   #5
DIY staff
Ub the second picture I see a grey plastic clip---does that lift up? Could that be the bottom track guide?
Old 07-15-2013, 09:06 PM   #6
Rewards Points: 71
yes, that metal (not plastic) clip is something from the bottom of the panel (same with upper panel). But I cannot move it or push it or do any thing with it.
Thanks for your advices.
Old 07-23-2013, 02:16 PM   #7
Rewards Points: 71
since I am unable to remove the closet sliding door, I assume I have to unscrew the tracks (upper & lower) to remove the doors, correct?
Old 07-23-2013, 02:32 PM   #8
Rewards Points: 6
The upper screw head adjusts the height of the door. There should be one one each side of the door. They will keep turning until the door bottom hits the bottom track or the top of the door hits the top track.
As you look at the screw, turn it counterclockwise a bunch of times. Watch the top edge of the door as you do it. You should see it move down. Once you have lowered it, try pulling up on the door to get it out of the track. The door will likely be heavy.
You should not have to unscrew the track to get the door out.
Dan
djlandkpl is online now   Reply With Quote
Old 08-04-2013, 07:07 PM   #9
Rewards Points: 71
ok, finally,
found I had to remove the bottom track first, lift the doors and slide the track side way.
then, unhooked the top wheels from upper track to remove the doors.
The Following User Says Thank You to young707 For This Useful Post:
oh'mike (08-05-2013)
updating 1970's plain closet bi-fold doors Kansas Girl Interior Decorating 13 04-01-2013 04:16 PM
Foul odor on closet doors after priming diybifold Painting 10 02-18-2013 05:48 PM
Combine 2 closet doors into 1 wide one Pauertule General DIY Discussions 4 01-14-2013 10:15 PM
sliding woodframe glass doors stephenbishop Windows and Doors 1 03-13-2012 08:11 AM
Painting a sliding closet door javan Painting 1 06-25-2008 11:47 AM
